SSH always 'access denied'
Having some real issues with the SSH addon. I have reinstalled it and set my password. However, no matter what account I try to use using Putty on my PC, I am greeted with access denied.
The log just says:
[INFO] Setup password login
[INFO] Restore host keys
debug1: Set /proc/self/oom_score_adj from 0 to -1000
debug1: Bind to port 22 on 0.0.0.0.
Server listening on 0.0.0.0 port 22.
debug1: Bind to port 22 on ::.
Server listening on :: port 22.
debug1: Forked child 21.
debug1: Set /proc/self/oom_score_adj to 0
debug1: rexec start in 5 out 5 newsock 5 pipe 7 sock 8
debug1: inetd sockets after dupping: 3, 3
Connection from 192.168.10.51 port 59694 on 172.30.33.0 port 22
debug1: Client protocol version 2.0; client software version PuTTY_Release_0.70
debug1: no match: PuTTY_Release_0.70
debug1: Local version string SSH-2.0-OpenSSH_7.7
debug1: permanently_set_uid: 22/22 [preauth]
debug1: ssh_sandbox_child: prctl(PR_SET_SECCOMP): Invalid argument [preauth]
debug1: list_hostkey_types: ssh-rsa,rsa-sha2-512,rsa-sha2-256,ecdsa-sha2-nistp256,ssh-ed25519 [preauth]
debug1: SSH2_MSG_KEXINIT sent [preauth]
debug1: SSH2_MSG_KEXINIT received [preauth]
debug1: kex: algorithm: [email protected] [preauth]
debug1: kex: host key algorithm: ssh-ed25519 [preauth]
debug1: kex: client->server cipher: aes256-ctr MAC: hmac-sha2-256 compression: none [preauth]
debug1: kex: server->client cipher: aes256-ctr MAC: hmac-sha2-256 compression: none [preauth]
debug1: expecting SSH2_MSG_KEX_ECDH_INIT [preauth]
debug1: rekey after 4294967296 blocks [preauth]
debug1: SSH2_MSG_NEWKEYS sent [preauth]
debug1: expecting SSH2_MSG_NEWKEYS [preauth]
debug1: SSH2_MSG_NEWKEYS received [preauth]
debug1: KEX done [preauth]
debug1: userauth-request for user hassio service ssh-connection method none [preauth]
debug1: attempt 0 failures 0 [preauth]
Invalid user hassio from 192.168.10.51 port 59694
debug1: Unable to open the btmp file /var/log/btmp: No such file or directory
debug1: userauth-request for user hassio service ssh-connection method keyboard-interactive [preauth]
debug1: attempt 1 failures 0 [preauth]
debug1: keyboard-interactive devs  [preauth]
debug1: auth2_challenge: user=hassio devs= [preauth]
debug1: kbdint_alloc: devices '' [preauth]
debug1: userauth-request for user hassio service ssh-connection method password [preauth]
debug1: attempt 2 failures 1 [preauth]
Could not get shadow information for NOUSER
Failed password for invalid user hassio from 192.168.10.51 port 59694 ssh2
Anyone have any ideas as I am pulling my hair out with this? Thanks
What’s your SSH config look like?
Mine is simply:
  "authorized_keys": [],
  "password": "raspberry"
Same:
  "password": "<redacted>"
Ahhh ignore me - being an utter idiot. Used the wrong username, was not using ‘root’! DOH!
The ‘SSH and web terminal’ addon does support a username now, however it cannot be upper case. It has to be all lowercase :
Cannot connect via ssh unless username with capital letters - it is misleading · Issue #395 · hassio-addons/addon-ssh (github.com)
Thank you that was my problem. It cannot to be UPPER CASE!!!
