Hi!
I’m having trouble with a command line switch with an ssh command
this is my configuration.yaml snippet:
switch:
- platform: command_line
switches:
win10:
command_on: "ssh -i /config/.ssh/id_ed25519 [email protected] sudo virsh start win10"
command_off: "ssh -i /config/.ssh/id_ed25519 [email protected] sudo virsh destroy win10"
command_state: "ssh -i /config/.ssh/id_ed25519 [email protected] sudo virsh dominfo win10 | grep running"
friendly_name: "Windows VM"
error message:
Command failed: ssh -i /config/.ssh/id_ed25519 [email protected] sudo virsh start win10
I put the ssh keys in the config directory because of this answer.
If I run the commands from the ssh terminal plugin it works just fine…
Additional Information:
Hassio 0.107.7 on RPi4
Thank you for your help!
