SSH from Terminal Permission Denied
I am trying to connect with SSH. I enabled the “Terminal & SSH” addon, created an ed25519 key on my computer, added port 22, and tried to connect from the terminal, however the connection gives me permission denied. If I add an use a password then it works.
This is my terminal output
~/.ssh$ ssh -v [email protected] -p 2222
OpenSSH_8.9p1 Ubuntu-3ubuntu0.7, OpenSSL 3.0.2 15 Mar 2022
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: include /etc/ssh/ssh_config.d/*.conf matched no files
debug1: /etc/ssh/ssh_config line 21: Applying options for *
debug1: Connecting to 192.168.8.177 [192.168.8.177] port 2222.
debug1: Connection established.
debug1: identity file /home/HOSTNAME/.ssh/id_rsa type -1
debug1: identity file /home/HOSTNAME/.ssh/id_rsa-cert type -1
debug1: identity file /home/HOSTNAME/.ssh/id_ecdsa type -1
debug1: identity file /home/HOSTNAME/.ssh/id_ecdsa-cert type -1
debug1: identity file /home/HOSTNAME/.ssh/id_ecdsa_sk type -1
debug1: identity file /home/HOSTNAME/.ssh/id_ecdsa_sk-cert type -1
debug1: identity file /home/HOSTNAME/.ssh/id_ed25519 type -1
debug1: identity file /home/HOSTNAME/.ssh/id_ed25519-cert type -1
debug1: identity file /home/HOSTNAME/.ssh/id_ed25519_sk type -1
debug1: identity file /home/HOSTNAME/.ssh/id_ed25519_sk-cert type -1
debug1: identity file /home/HOSTNAME/.ssh/id_xmss type -1
debug1: identity file /home/HOSTNAME/.ssh/id_xmss-cert type -1
debug1: identity file /home/HOSTNAME/.ssh/id_dsa type -1
debug1: identity file /home/HOSTNAME/.ssh/id_dsa-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_8.9p1 Ubuntu-3ubuntu0.7
debug1: Remote protocol version 2.0, remote software version OpenSSH_9.6
debug1: compat_banner: match: OpenSSH_9.6 pat OpenSSH* compat 0x04000000
debug1: Authenticating to 192.168.8.177:2222 as 'USERNAME'
debug1: load_hostkeys: fopen /home/HOSTNAME/.ssh/known_hosts2: No such file or directory
debug1: load_hostkeys: fopen /etc/ssh/ssh_known_hosts: No such file or directory
debug1: load_hostkeys: fopen /etc/ssh/ssh_known_hosts2: No such file or directory
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: algorithm: curve25519-sha256
debug1: kex: host key algorithm: ssh-ed25519
debug1: kex: server->client cipher: [email protected] MAC: <implicit> compression: none
debug1: kex: client->server cipher: [email protected] MAC: <implicit> compression: none
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: SSH2_MSG_KEX_ECDH_REPLY received
debug1: Server host key: ssh-ed25519 SHA256:REDACTED
debug1: Host '[192.168.8.177]:2222' is known and matches the ED25519 host key.
debug1: Found key in /home/HOSTNAME/.ssh/known_hosts:16
debug1: ssh_packet_send2_wrapped: resetting send seqnr 3
debug1: rekey out after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: ssh_packet_read_poll2: resetting read seqnr 3
debug1: SSH2_MSG_NEWKEYS received
debug1: rekey in after 134217728 blocks
debug1: get_agent_identities: bound agent to hostkey
debug1: get_agent_identities: agent returned 1 keys
debug1: Will attempt key: HomeAssistantSSH ED25519 SHA256:REDACTED agent
debug1: Will attempt key: /home/HOSTNAME/.ssh/id_rsa
debug1: Will attempt key: /home/HOSTNAME/.ssh/id_ecdsa
debug1: Will attempt key: /home/HOSTNAME/.ssh/id_ecdsa_sk
debug1: Will attempt key: /home/HOSTNAME/.ssh/id_ed25519
debug1: Will attempt key: /home/HOSTNAME/.ssh/id_ed25519_sk
debug1: Will attempt key: /home/HOSTNAME/.ssh/id_xmss
debug1: Will attempt key: /home/HOSTNAME/.ssh/id_dsa
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,[email protected],[email protected],rsa-sha2-512,rsa-sha2-256>
debug1: kex_input_ext_info: [email protected]=<0>
debug1: kex_input_ext_info: [email protected] (unrecognised)
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey,keyboard-interactive
debug1: Next authentication method: publickey
debug1: Offering public key: HomeAssistantSSH ED25519 SHA256:REDACTED agent
debug1: Trying private key: /home/HOSTNAME/.ssh/id_rsa
debug1: Trying private key: /home/HOSTNAME/.ssh/id_ecdsa
debug1: Trying private key: /home/HOSTNAME/.ssh/id_ecdsa_sk
debug1: Trying private key: /home/HOSTNAME/.ssh/id_ed25519
debug1: Trying private key: /home/HOSTNAME/.ssh/id_ed25519_sk
debug1: Trying private key: /home/HOSTNAME/.ssh/id_xmss
debug1: Trying private key: /home/HOSTNAME/.ssh/id_dsa
debug1: Next authentication method: keyboard-interactive
debug1: No more authentication methods to try.
[email protected]: Permission denied (publickey,keyboard-interactive).
Did you ever get this working? I’m experiencing the same exact issue.
Yes!. In the Config tab, add some password and enable Port 22. The documentation says the user is root - I was initially trying with my owner account.
So from CMD - ssh root@
