SSH Hassio
thanks I’ve got it all sorted
would you care to share how you managed? i have the same question.
Created all keys, renamed the public key to authorized_keys and think i copied it to the root of my Pi3 running Hassio.
That is, I uploaded it to /root which shows when sftp to [email protected] with my ssh credentials.
/resin-boot doesn’t show though, which should be the root to copy the file to. How can i copy a file there, if i cant see it first…?
cheers,
Marius
Remove SD card and plug in to computer open resin-boot there just drag ‘authorised_keys’ into it. Plug back into pi and as long as your private key is on your .ssh file of your computer it should work. Go to [email protected] -p 22222 make sure to use port 22222.
More info is here:
thanks, just managed to do so. check Curl > json command for the other guideline @NotoriousBDG assisted on.
Once you know, it couldn’t be simpler…
Cheers,
Marius
