I try to ssh into the host of my hassio install (create a dummy soundcard).
I followed these instructions: https://developers.home-assistant.io/docs/en/hassio_debugging.html
However, when I try to access the host via <IP.adress>:22222 with my new private key, it seems I still log into hassio:
The result
hassio > Error: unknown command "journalctl" for "hassio-cli"
Run 'hassio-cli --help' for usage.
FATA[0000] Error while executing rootCmd: unknown command "journalctl" for "hass io-cli"
What Am I doing wrong?
