I have two problems. After the crash of my Raspberry, SSD card did not work, I did a full new installation to Hass.io. Now I have two problems. The setup of SSH is not working trough the front end. When I install the SSH server in the app store and try to start it is not working and get 502 bad gateway.
When I install the SSH & Web terminal the same issue.
Also trying to get remote in the system via terminal server on my mac book
ssh: connect to host 192.168.1.21 port 22: Connection refused
Second problem. The system did not setup the Z wave USB dongle. Normally I can do this via the terminal server to get the software. Also with a screen and keyboard on the pi is getting me stranded.
If I try to setup the zwave network I do not see the dongle. If I go to settings and zwave network I try to start the network but without any succes. I left the machine for one hour but nothing is visible.
Yes but they are not visible in my zwave network. When I’m going to integrations -> zwave it is empty and no things are connected. The auto add is switched on.
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] permissions: applying…
[fix-attrs.d] permissions: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] 00-banner.sh: executing…
Hass.io Add-on: SSH & Web Terminal
SSH & Web Terminal access to your Home Assistant instance
Add-on version: 7.0.1
You are running the latest version of this add-on.
System: HassOS 3.7 (armv7 / raspberrypi3)
Home Assistant version: 0.103.5
Supervisor version: 193
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing…
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] docker.sh: executing…
[cont-init.d] docker.sh: exited 0.
[cont-init.d] ssh.sh: executing…
[16:38:29] FATAL:
[16:38:29] FATAL: Configuration of this add-on is incomplete.
[16:38:29] FATAL:
[16:38:29] FATAL: Please be sure to set a least a SSH password
[16:38:29] FATAL: or at least one authorized key!
[16:38:29] FATAL:
[16:38:29] FATAL: You can configure this using the “ssh.password”
[16:38:29] FATAL: or the “ssh.authorized_keys” option in the
[16:38:29] FATAL: add-on configuration.
[16:38:29] FATAL:
[cont-init.d] ssh.sh: exited 1.
[cont-finish.d] executing container finish scripts…
[cont-finish.d] 99-message.sh: executing…
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
