Suddenly I found that I cannot connect to HA using putty. The message tells me that connection is refused. It used to work but I do not remember when was the last time I used it.
When I restart HA or just restart “Terminal & SSH” Add-On, I see the following:
[10:05:45] INFO: Starting Web Terminal...
[2020/06/20 10:05:45:1610] N: ttyd 1.6.0-c15cfb7 (libwebsockets 3.2.2)
[2020/06/20 10:05:45:1611] N: tty configuration:
[2020/06/20 10:05:45:1611] N: start command: tmux -u new -A -s homeassistant bash -l
[2020/06/20 10:05:45:1613] N: close signal: SIGHUP (1)
[2020/06/20 10:05:45:1613] N: terminal type: xterm-256color
[2020/06/20 10:05:45:1976] N: Using foreign event loop...
[2020/06/20 10:05:45:1984] N: Listening on port: 8099
[10:05:45] WARNING: SSH port is disabled. Prevent start of SSH server.
This is the configuration for my “Terminal & SSH” Add-On. Can someone help me?
I moved from a synology Virtual Machine manager to Raspberry PI 4 supervised.
make a backup and restore it to the new install on de Pi all dashboards are working wel !!
the terminal works perfect on the synology I see in the log “INFO: Service restart after closing”
but not on the Pi I only need a terminal in HA not SSH
Back to Clean install, then restore HAform backup but NOT the Add-on’s Terminal SSH & File editor.
Every thing ok, then install the two add-ons’s (with the correct arch X64 vs Arm that’s it !!
How did you pick the x64 arch when installing the add on? I tried a restore to move my system from a Pi to a x86 system and all the addons failed but I can’t seem to get the proper arch versions installed. When I uninstall and then reinstall they still don’t start.
I run Home Assistant on Raspberry PI with latest version. I removed the addins(ssh and file editor), reboot and re-installed. Same error;
“SSH port is disabled. Prevent start of SSH server”.
Also the menu item for network under configuration to enter the port number is not shown at all.
Don’t like to go for a clean install.
After setting the slider ‘Show disabled ports’, I was able to provide a custom value.(tried 2222) After that I could connect with Putty using this custom port, although the logging still says it is listening on port 22!? I tried port 22 just to check, but then I get ‘connection refused’.
