I am running Home Assistant OS on an intel NUC.
Almost everything is working well…
I’m trying to login to homeassistant with SSH. Connect trough putty I can login with the set credentials in the ssh addon. I get this screen:
When I type ‘login’ to get core acces, the shell asks another login and password. What are those or how can I change them?
It’s not the same as the set password that I use to acces ssh. Also, root doesn’t work. It says: login incorrect. With other usernames I can type a password.
Thanks!
