SSH Tunnel to VPS and Trusted Network
Hi all,
I have setup my home assistant with an ssh tunnel to my vps with apache using reverse proxy however when I use the trusted network authentication, it will allow to connect with a trusted user remotely without using a password, is it a normal behavior, because of the ssh tunnel it considers it as a local connection ? Does anyone has a workaround ?
Thanks in advance and regards,
Benji
