Hi, I am sharing the workaround I developed since migrating to docker, that allows SSH to work properly once again.
I use the ssh command to send instructions for remote operations to linux boxes like Raspberry Pis that I have deployed for various purposes. Since migrating my Home Assistant instance to docker these started failing with the error
No user exists for uid xxxx
People who try to run git inside their docker containers might find the same issue too. The error occurs because the docker configuration makes the container run in the context of a user id that only exists in the docker host, not in the container.
No surprisingly the solution is to add the user into the container, so this is done with a Dockerfile, referred to in the Compose file
Dockerfile
# Dockerfile to address issue 'No user exists for uid xxxx'
# with shell_command 'ssh user@server 2 >command.log' or git or similar
FROM homeassistant/home-assistant
# accept the arguments from .Env (via compose file)
ARG PUID
ARG PGID
ARG USER
# Add the group (if not existing)
# then add the user to the numbered group
RUN addgroup -g ${PGID} ${USER} || true && \
adduser -D -u ${PUID} -G `getent group ${PGID} | cut -d: -f1` ${USER} || true
LABEL vcs-url=https://github.com/artmg/home-assistant-docker
docker-compose.yaml
homeassistant:
# image: homeassistant/home-assistant
build:
context: .
args:
- PUID=${PUID}
- PGID=${PGID}
- USER=${USER}
image: home-assistant:home-assistant-docker-adduser
Instructions
# you can set these by hand, but easiest in a .env file
#PUID=UserID you want to run the Docker containers under
#PGID=GroupID of the docker group
PUID=`id -u $USER`
PGID=`getent group docker | cut -d: -f3`
docker-compose up -d --rebuild
I hope this helps people who run into similar issues - please ask if you have queries or issues.
