Hi, noob here, i have a HA and want to control a pie running raspbian. I created 3 scripts: 1)Open a web page, 2)Close chromium, 3)Shutdown the pie
But each time i run the Open web page, the other scripts dont work until i manually close the web page but the code works on the SSH terminal, any ideas? heres the code
Just putting chromium in the background is not enough. The process is still attached to the shell, so it won’t return after launching (and likely error in a timeout, check the logs).
Thanks for all the help!!, i can successfully run the SAME commands on the Openweb, BUT when i run the scripts with the commands thats when script “close” and “shutdown” dont work
Can you send me an example of nohup?, im 100% noob on this and got an error when running this:
