As a heads up only:
I noticed different behaviors on sonoffs running the basic vs classic version of Tasmota 6.4.1. I didn’t find anything on the documentation or in other posts, so here it goes.
Sonoffs flashed with sonoff-basic-6.4.1.bin, upon power up and 4 short clicks correctly start wifi manager providing an SSID named sonoff-NNNN with DHCP and web-ui at 192.168.4.1. From there configuring is a breeze. Some examples are:
Sonoffs flashed with Sonoff-classic-6.4.1.bin upon power up already start with an access point at 192.168.4.1 but the connection is very unstable and there is no web ui. The SSID is in the format ESP_NNNNNN as can be seen below:
As there’n no web ui I connected via serial to check what could be going on, and I could see one reset every 4 secs:
00:00:00 Project sonoff Sonoff Version 6.4.1(classic)-2_4_2
00:00:00 WIF: WPSConfig failed to start
00:00:04 APP: Restarting
ets Jan 8 2013,rst cause:1, boot mode:(3,6)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld
If I’m able to type SSID and PASSWORD commands fast enough between two resets I can get it to work. At that point the web server becomes active.
00:00:00 WIF: Connecting to AP1 TTNet in mode 11N as sonoff-3430...
00:00:06 WIF: Connected
00:00:06 DNS: Initialized
00:00:06 HTP: Web server active on sonoff-3430.local with IP address 192.168.200.60
01:01:07 MQT: Attempting connection...
01:01:08 DNS: Query done. MQTT services found 0
01:01:18 MQT: Attempting connection...
01:01:19 DNS: Query done. MQTT services found 0
[Disconnected]
Am I doing something wrong with the classic version of the binary?
If this is discussed/solve somewhere else please forgive me. I’ve been in this world for a few weeks only.
Tales Maschio - thermseekr
