I want to set up SSL and a secure port for accessing HA externally. No, I don’t want to use duck dns or whatever it’s called and I don’t use free certs. I have an existing wildcard cert from another CA and would like to integrate that into HA. “Should” be a fairly simple and basic requirement but I’ve yet to find any information as to how to actually do it.
I’ve done a reverse proxy setup, so i use other werbserver for ssl negotiation and then route reqeusts to HA. done in Synology, which makes it pretty simple with UI setup. Behind it its nginx, so you could look at that too.
