Ssl certificate error using duckdns on internal network
My pi3 and my pc are connected via cables to my Arris router. No ports are forwarded (yet). I have a static IP in my router and no USB stick for the pi. Fresh hassio config on sd card using the latest from hassio web and balenaEtcher. After 20 min log in to HA. Load add-0ns configurator and duckdns. I have the duckdns token from doing this prior. Modify the config for duckdns as follows
“lets_encrypt”: {
“accept_terms”: true,
“certfile”: “fullchain.pem”,
“keyfile”: “privkey.pem”
“token”: “xxxxxxxxxxxxmy_tokenxxxxxxxxxxxxxxxxxx”,
“domains”: [“my_domain.duckdns.org”
“seconds”: 300
I start duckdns and no errors, certificates generated in the ssl directory.
> # INFO: Using main config file /data/workdir/config
> + Generating account key...
> + Registering account key with ACME server...
> + Done!
> Sun Jun 23 15:50:48 PDT 2019: OK
> 75.33.193.66
> NOCHANGE
>  + Creating chain cache directory /data/workdir/chains
> Processing my_domain.duckdns.org
>  + Creating new directory /data/letsencrypt/my_domain.duckdns.org ...
>  + Signing domains...
>  + Generating private key...
>  + Generating signing request...
>  + Requesting new certificate order from CA...
>  + Received 1 authorizations URLs from the CA
>  + Handling authorization for my_domain.duckdns.org
>  + 1 pending challenge(s)
>  + Deploying challenge tokens...
> OK + Responding to challenge for my_domain.duckdns.org authorization...
>  + Challenge is valid!
>  + Cleaning challenge tokens...
> OK + Requesting certificate...
>  + Checking certificate...
>  + Done!
>  + Creating fullchain.pem...
>  + Done!
> core-ssh:/ssl# ls
> fullchain.pem  privkey.pem
> core-ssh:/ssl#
Check the home-assistant.log from the configurator - nothing
Check the system log from the HA interface hass.io → system - seems ok
> 19-06-23 22:49:43 INFO (MainThread) [hassio.addons] Create Home Assistant add-on data folder /data/addons/data/core_duckdns
> 19-06-23 22:49:43 INFO (SyncWorker_16) [hassio.docker.interface] Pull image homeassistant/armv7-addon-duckdns tag 1.6.
> 19-06-23 22:49:47 INFO (SyncWorker_16) [hassio.docker.interface] Tag image homeassistant/armv7-addon-duckdns with version 1.6 as latest
> 19-06-23 22:50:12 INFO (SyncWorker_10) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-duckdns with version 1.6
I remove the ‘#’ from the http: and add the ssl info in the configuration.yaml and save
> http:
>   base_url: "https://my_domain.duckdns.org"
>   ssl_certificate: /ssl/fullchain.pem
>   ssl_key: /ssl/privkey.pem
Hit check config and then restart
I am never able to log back in post rebooting using (http://my_ip:8123 or https://my_ip:8123)
This is the error in the home-assistant.log
> ) 2019-06-20 21:13:30 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed Traceback (most recent call last): File "uvloop/sslproto.pyx", line 500, in uvloop.loop.SSLProtocol._on_handshake_complete File "uvloop/sslproto.pyx", line 484, in uvloop.loop.SSLProtocol._do_handshake File "/usr/local/lib/python3.7/ssl.py", line 763, in do_handshake self._sslobj.do_handshake() ssl.SSLError: [SSL: SSLV3_ALERT_CERTIFICATE_UNKNOWN] sslv3 alert certificate unknown (_ssl.c:1056)
I have received several valuable comments here, but noting has solved the problem of being able to log back in from my pc. I have a mac on the network and tried safari and that too didn’t work. I was told in that other thread that getting https://my_domain.duckdns.org:8123 was troublesome for some routers and some had to forego using https. I assume that I do not need to port forward any router ports (tet) if I am trying to solve this issue on my local network. If I needed to port forward anything in the above steps to connect using https: please let me know: note that port 80 is unavailable on my AT&T router.
You now have to use https: but the SSL certificates are for your duckdns url only. Not for the ip address and not for hassio.local.
You can override this in your web browser by adding a certificate exception. Navigate to https://your_ip:8123 and follow the web page prompts. If you clear your browser history you will have to do this again.
There was no need to start a new topic.
Thank you. I was able to force using https:my_ip:8123 however it did show not secure in the browser.
I then set port 8123 to forward to 8123 and then port 443 to forward to 443 and tried my duckdns url
https://www.my_domain.duckdns.org or https://www.my_domain.duckdns.org:8123
and then pulled this from the home-assistant.log
2019-06-24 04:33:11 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
I am starting to think I am doing something fundamentally wrong or there is something fundamentally wrong with my network
Is there some data I should pull that would be useful and help with getting duckdns to work? should I go back to the other thread?
This was in the hassio system log. not sure if it is applicable
19-06-24 03:53:25 WARNING (MainThread) [hassio.api.ingress] No valid ingress session 6272a26f1c49ba79f59628c64c652fe579f0117f86d0441e06576632412bdd6b6fe0b46576db61907a709f79d1273b6bb29cd255e7dc4e43e632f9c5af8ded4c
As I and everyone else keeps telling you this is because the ssl certificate is for your duckdns address not the ip address. The link is encrypted. The browser is just warning you that the certificate is not trusted as it does not apply to the ip address.
Drop the www, it’s just: https://my_domain.duckdns.org:8123
Now that you have your router with port forwarding 8123->8123 (by the way you shouldn’t need to port forward 443), I would suggest try using your mobile device in cellular mode (not your home WiFi) to get access to https://my_domain.duckdns.org:8123. If that works then great!!
Some routers but not all support what I would call a “hairpin” which allows you to use https://my_domain.duckdns.org:8123 inside your home network. The router attempts to forward your request but realizes the resulting address is its own WAN port and instead forwards it back through your firewall including port forwarding towards your home network. But like I said, not all routers support this. If I recall, my ATT router did not support this.
