SSL Certificate installation for HA on QNAP docker container
I have HA installed on a QNAP NAS on a docker container.
I copied my SSL Certificate from myqnapcloud ddns to the /config folder after converting it from .crt type to .pem type and this seemed to make it work when browsing to my server using chrome.
Now I’ve been trying to install haaska and I’m getting an error from AWS that my certificate is not valid. Anyone have an idea why or how to fix it?
a certificate is valid for a domain name. If your certificate has a valid domain name and that domain name actually points to your public IP, and everything is forwarded correctly it should work.
and yet it doesn’t, I had the same issue with the “regular” home assistant skill which I solved by uploading the certificate to the developer consule instead of using the endpoint, but I dont have the same option for haaska skill
Hi @ido_1,
I’m really new to HA and I’m hoping you could help me out. Can you post the instructions on how you convert to .pem type along with where is the /Config folder located?
Thanks,
Ryan
