I know there are other posts about similar issues but I’m having trouble finding out what component is actually causing this. This started a few weeks ago but I kind of ignored it because nothing seemed broken. Unfortunately this started on a night I upgraded to Python 3.7, and the same night apple broke pyicloud… any help in how to narrow this down would be appreciated. Nothing actually stands out as being “broken” because of this but I also didn’t want to just suppress the message if something is broken that I just haven’t noticed yet.
2019-06-30 20:09:57 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed on verifying the certificate
File "/usr/local/lib/python3.7/asyncio/sslproto.py", line 625, in _on_handshake_complete
raise handshake_exc
File "/usr/local/lib/python3.7/asyncio/sslproto.py", line 189, in feed_ssldata
self._sslobj.do_handshake()
File "/usr/local/lib/python3.7/ssl.py", line 763, in do_handshake
ssl.SSLCertVerificationError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self signed certificate (_ssl.c:1056)
2019-06-30 20:09:57 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error in data received
File "/usr/local/lib/python3.7/asyncio/sslproto.py", line 526, in data_received
ssldata, appdata = self._sslpipe.feed_ssldata(data)
I also found this a few lines below…
2019-06-30 20:09:57 DEBUG (MainThread) [homeassistant.components.ssdp] Error fetching http://192.168.1.1:1990/WFADevice.xml: None
2019-06-30 20:09:57 DEBUG (MainThread) [homeassistant.components.ssdp] Error fetching https://192.168.1.11:8888: Cannot connect to host 192.168.1.11:8888 ssl:True [SSLCertVerificationError: (1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self signed certificate (_ssl.c:1056)')]
That IP address is for my WinkHub 2 - but I’m not seeing anyone else using Wink mentioning a problem. I’ve tried disabling a few components and restarting but so far it’s still there. Aside from one by one removing integrations/removing items from my config does anyone know how I could narrow down the source of this error?
