Just bought another RPI to set up HA, very eager and slightly frustrated so far.
So I’ve tried to find other posts about this. Maybe I have but I just didn’t understand…
DuckDNS is set up and after reinstalling it, everything works as it should, according to the log anyway.
Now comes where I’m stuck. Even if DuckDNS is installed and ok, I can’t access it through mydomain.duckdns.org. I’ve forwarded 443 to 8213 and 3218 to 3218( for Configurator).
When I try to access the duckdns url, I still end up viewing my routers (google wifi) welcome page. It’s close, but I’m stuck.
Problem two (probably related…) is with the Configurator. I get these error messages:
Configuration invalid CHECK CONFIG
Component not found: base_url
Component not found: ssl_key
Component not found: ssl_certificate
In configurator it looks like this:
“username”: “xxxx”,
“password”: “xxxx”,
“ssl”: true,
“certfile”: “fullchain.pem”,
“keyfile”: “privkey.pem”,
“allowed_networks”: [
“192.168.0.0/16”,
“172.30.0.0/16”
and
http:
base_url: https://xxx.duckdns.org:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
So before I actually start to set things up, I want thee basics done.
It’s probably and easy fix but I’m out of options here…
Thanks in advance!
S
