SSL connection with dyn ok, but could not connect with internal ip
Hi!
I can connect to my home assistant from my external SSL connection “https://xxx.spdns.de”.
But when I try to connect with my internal IP “https://192.168.178.15:8123” the login site appears, then I enter the correct password. The result is: “Unable to connect
My routing settings:
443:8123
I’m using HassIO with the Let’s Encrypt addon.
Is it not possible to connect with the internal ip?
Thank you
