Ssl error, whats wrong?
Invalid config for [http]: [api_password] is an invalid option for [http]. Check: http->http->api_password. (See /config/configuration.yaml, line 26).
#http:
api_password: long lived access token from home assistant
ssl_certificate: /etc/letsencrypt/live/thedomain/fullchain.pem
ssl_key: /etc/letsencrypt/live/thedomain/privkey.pem
why isnt this working?
Please read point 11 of the community guidelines and format your code correctly.
The error tells you exactly what the problem is, api_password is not a valid option for http. You can see the available options in the docs here.
