Hi All,
All of a sudden I’ve started to get get a streams of errors in my log which look like this:
2018-11-20 21:40:04 WARNING (MainThread) [homeassistant.components.http] legacy_api_password support has been enabled. If you don't require it, remove the 'api_password' from your http config.
2018-11-20 22:45:25 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal error on SSL transport
File "/usr/lib/python3.6/asyncio/sslproto.py", line 638, in _process_write_backlog
ssldata, offset = self._sslpipe.feed_appdata(data, offset)
AttributeError: 'NoneType' object has no attribute 'feed_appdata'
2018-11-20 22:45:25 WARNING (MainThread) [homeassistant.components.cloud.iot] Connection closed: Received non-Text message: 8
2018-11-20 22:45:41 ERROR (MainThread) [homeassistant.components.cloud.iot] Unexpected error
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/vendored/requests/packages/urllib3/util/ssl_.py", line 267, in ssl_wrap_socket
FileNotFoundError: [Errno 2] No such file or directory
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/vendored/requests/adapters.py", line 370, in send
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/vendored/requests/packages/urllib3/connectionpool.py", line 544, in urlopen
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/vendored/requests/packages/urllib3/connectionpool.py", line 341, in _make_request
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/vendored/requests/packages/urllib3/connectionpool.py", line 761, in _validate_conn
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/vendored/requests/packages/urllib3/connection.py", line 238, in connect
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/vendored/requests/packages/urllib3/util/ssl_.py", line 269, in ssl_wrap_socket
botocore.vendored.requests.packages.urllib3.exceptions.SSLError: [Errno 2] No such file or directory
File "/home/leon/homeassistant/lib/python3.6/site-packages/homeassistant/components/cloud/iot.py", line 68, in connect
File "/home/leon/homeassistant/lib/python3.6/site-packages/homeassistant/components/cloud/iot.py", line 100, in _handle_connection
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/home/leon/homeassistant/lib/python3.6/site-packages/homeassistant/components/cloud/auth_api.py", line 108, in check_token
File "/home/leon/homeassistant/lib/python3.6/site-packages/warrant/__init__.py", line 260, in check_token
File "/home/leon/homeassistant/lib/python3.6/site-packages/warrant/__init__.py", line 555, in renew_access_token
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/client.py", line 314, in _api_call
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/client.py", line 599, in _make_api_call
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/endpoint.py", line 148, in make_request
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/endpoint.py", line 177, in _send_request
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/endpoint.py", line 273, in _needs_retry
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/hooks.py", line 227, in emit
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/hooks.py", line 210, in _emit
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/retryhandler.py", line 183, in __call__
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/retryhandler.py", line 251, in __call__
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/retryhandler.py", line 277, in _should_retry
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/retryhandler.py", line 317, in __call__
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/retryhandler.py", line 223, in __call__
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/retryhandler.py", line 359, in _check_caught_exception
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/endpoint.py", line 222, in _get_response
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/vendored/requests/sessions.py", line 573, in send
File "/home/leon/homeassistant/lib/python3.6/site-packages/botocore/vendored/requests/adapters.py", line 431, in send
botocore.vendored.requests.exceptions.SSLError: [Errno 2] No such file or directory
2018-11-20 22:45:58 ERROR (MainThread) [homeassistant.components.cloud.iot] Unexpected error
And they just go on and on. This appears to completely break my Google Assistant integration (assuming because its related to the cloud component).
Any help in trying to figure out what has broken would be a huge help.
I’m running Home Assistant on Ubuntu 17.10 (GNU/Linux 4.13.0-39201805060708-generic x86_64)
Thank you!
