Hi guys!
Right now I’m using my HA installation with port forwarding. So it’s accessible remotely with my public IP address with DDNS (own domain name server, not DuckDNS). It’s SSL/TLS encrypted with Let’s Encrypt.
I just found out my router directly supports VPN, so I want to hide my HA by removing the port forwarding and make it accessible via VPN only.
Since it will not be accessible with the public IP and DDNS domain but only with the private IP address (and it’s hostname), I’m wondering if it is still useful to keep the SSL/TLS encryption?
As far as I understand I can’t use Let’s encrypt to generate a certificate because the HA isn’t accessible anymore. If I should keep the encryption, how would I do that?
Thanks and regards!
