Quick question. Getting SSL set up was one of the 1st things I did with my HA install, and honestly it’s just been working and I’ve forgotten/neglected it. Anyway, found my front end was not accessible today, and it looks like my SSL cert has expired.
So, I believe I set my ssl cert up following this tutorial
but maybe I never set up the cron job, or its been erroring and I did not noticed. Either way, I just want to make sure I fully understand what I need to do.
If I just activate my VENV and run the following command, will that fix everything?
dehydrated -c
Or do I need to go through the whole process again, since it expired.
You need to navigate to the folder where that script is stored. I don’t believe you have to activate the VENV. I have run splitbrains setup with and without activating it, both work.
When I first tried to renew, I got an error saying dehydrated was not installed and to do an
apt install dehydrated
which I did
But now I see my errors are path related
INFO: Using main config file /etc/dehydrated/config
ERROR: The path /etc/dehydrated/conf.d specified for CONFIG_D does not point to a directory.
I’ve removed dehydtated with an
apt remove dehydrated
I’ve reinstalled, removed the home/homeassitant/dehydrated folder, and tried to start over, it seems as if it keeps expecting me to be the the /etc folder, I even put my domains.txt in the folder
I’ve opened port 80, 8123, 443, on my router, closed them back. Overall I feel lost. I do remember this was confusing when I 1st did it months ago, because there were so many ways to do this, and the methods were different depending on if it was hass.io, etc
I’m runninging in a python venv. Also I’ve tried this as root, as homeassistant, I’ve set permissions to 777 on folders, and files, overall at this point I have no ssl , but at least I can access the front end for a bit.
If anyone can help me get this straight, I’d really appreciate it. I’m sure its more of an OS/config issue vs HA, but any help is appreciated
