I’ve been pulling my hair out the past couple of hours, as far as that is still possible. I need a hand, regarding a network connectivity after my cable modem has been set into bridge mode.
Here’s my config
- Home Assistant running in a Docker container on a Raspberry Pi 4
- Connected to a Mikrotik Routerboard RB2011
- DuckDNS domain
- Letsencrypt SSL on the host of the Raspberry Pi
- Certificate Expiry integration is installed in HomeAssistant
- My Mikrotik router refreshes the IP address at DuckDNS by means of a script
Here’s what happened
Everything was working fine until:
- I switched my cable modem into bridge mode
- This resulted in a change in external IP address
- No longer a a dual NAT situation. My router now holds the external IP address
Status
- The HA app on my mobile phone no longer connects
- On the local network, connecting to
xxx.duckdns.org
fails - Connecting to
https://<hass.local>:8123
works, but with an error that the connection is not secure - The sensor
sensor.cert_expiry_timestamp_xxx_duckdns_org
shows ‘unavailable’
Here is what I did so far, that led to no results
- Patience is a virtue, so I waited a bit for DNS servers to propagate the new IP address
- Checked my IP address in the router. It was in line with what DuckDNS was expecting
- Rebooted router, Pi and HomeAssistant in various order
- Cleared the cache on the phone, the laptop and in the router
- Specifically flushed the DNS cache in the router
- Forced renewal of the SSL certificates
- Upgraded to the latest HomeAssistant
Here’s what I did to debug
- Removed the SSL entries (ssl_certificate and ssl_key) in configuration.yaml to check if unsecured access works. It did, so the routes in the router are OK. I can connect to
http://xxx.duckdns.org:8123
. The routes to port 443 are similarly setup as to port 8123. - Set the log level to
debug
, but no needle in the haystack
So my guess is that something is very much wrong with the secure connection, but I cannot figure out what it is. Somewhere in the back of my mind it says that it might be something obvious, but like I said: no hair left to pull out.
Any clues? Thanks a million!
