SSL Proxy nginx configuration
Is it possible to edit the nginx configuration from the SSL proxy plugin? I would like to only allow access from certain IP address ranges to my hassio instance. If I could edit the nginx config it would be an easy way to an this ACL as it’s supported by nginx
