I’ve been trying to solve a connection problem related to a custom integration that was working flawlessly for a while. I’ve removed and reinstall the integration and even change my home assistant core installation to home assistant on a docker, if that change something.
The error I’m having is the following:
This error originated from a custom integration.
Logger: custom_components.kia_uvo.config_flow
Source: custom_components/kia_uvo/config_flow.py:63
Integration: Hyundai / Kia Connect (documentation, issues)
First occurred: 7:24:12 AM (1 occurrences)
Last logged: 7:24:12 AM
Unexpected exception
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 703, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 386, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 1042, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.10/site-packages/urllib3/connection.py", line 419, in connect
self.sock = ssl_wrap_socket(
File "/usr/local/lib/python3.10/site-packages/urllib3/util/ssl_.py", line 449, in ssl_wrap_socket
ssl_sock = _ssl_wrap_socket_impl(
File "/usr/local/lib/python3.10/site-packages/urllib3/util/ssl_.py", line 493, in _ssl_wrap_socket_impl
return ssl_context.wrap_socket(sock, server_hostname=server_hostname)
File "/usr/local/lib/python3.10/ssl.py", line 513, in wrap_socket
return self.sslsocket_class._create(
File "/usr/local/lib/python3.10/ssl.py", line 1071, in _create
self.do_handshake()
File "/usr/local/lib/python3.10/ssl.py", line 1342, in do_handshake
self._sslobj.do_handshake()
ssl.SSLError: [SSL: WRONG_SIGNATURE_TYPE] wrong signature type (_ssl.c:997)
File "/usr/local/lib/python3.10/site-packages/requests/adapters.py", line 489, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 787, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.10/site-packages/urllib3/util/retry.py", line 592, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='kiaconnect.ca', port=443): Max retries exceeded with url: /tods/api/lgn (Caused by SSLError(SSLError(1, '[SSL: WRONG_SIGNATURE_TYPE] wrong signature type (_ssl.c:997)')))
File "/config/custom_components/kia_uvo/config_flow.py", line 159, in async_step_user
await validate_input(self.hass, user_input)
File "/config/custom_components/kia_uvo/config_flow.py", line 63, in validate_input
token: Token = await hass.async_add_executor_job(
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.10/site-packages/hyundai_kia_connect_api/KiaUvoApiCA.py", line 124, in login
response = self.sessions.post(url, json=data, headers=headers)
File "/usr/local/lib/python3.10/site-packages/requests/sessions.py", line 635, in post
return self.request("POST", url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.10/site-packages/requests/sessions.py", line 587, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.10/site-packages/requests/sessions.py", line 723, in send
history = [resp for resp in gen]
File "/usr/local/lib/python3.10/site-packages/requests/sessions.py", line 723, in <listcomp>
File "/usr/local/lib/python3.10/site-packages/requests/sessions.py", line 266, in resolve_redirects
resp = self.send(
File "/usr/local/lib/python3.10/site-packages/requests/sessions.py", line 701, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.10/site-packages/requests/adapters.py", line 563, in send
raise SSLError(e, request=request)
requests.exceptions.SSLError: HTTPSConnectionPool(host='kiaconnect.ca', port=443): Max retries exceeded with url: /tods/api/lgn (Caused by SSLError(SSLError(1, '[SSL: WRONG_SIGNATURE_TYPE] wrong signature type (_ssl.c:997)')))
I’m not aware of any update on the system that could have cause this. However, my 64 bit raspberry pi OS does have security updates made automatically.
Thans in advance!
