I am unable to use my custom external display for my ST7789 based display.
Display type: ZJY-IPS130-V2.0, 240x240, ST7789, SPI
I have made optimizations for that implementation to use a line buffer instead of a full frame buffer so that it takes less memory and to be able to use it with an ESP8266.
Here is the error I get recently when I try to update it:
INFO ESPHome 2023.12.9
INFO Reading configuration /config/esphome/growtent-03.yaml...
WARNING GPIO5 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO15 is a strapping PIN and should only be used for I/O with care.
WARNING GPIO12 is a strapping PIN and should only be used for I/O with care.
INFO Generating C++ source...
File "/usr/local/bin/esphome", line 33, in <module>
sys.exit(load_entry_point('esphome', 'console_scripts', 'esphome')())
File "/esphome/esphome/__main__.py", line 1041, in main
return run_esphome(sys.argv)
File "/esphome/esphome/__main__.py", line 1028, in run_esphome
rc = POST_CONFIG_ACTIONS[args.command](args, config)
File "/esphome/esphome/__main__.py", line 458, in command_run
exit_code = write_cpp(config)
File "/esphome/esphome/__main__.py", line 192, in write_cpp
generate_cpp_contents(config)
File "/esphome/esphome/__main__.py", line 204, in generate_cpp_contents
CORE.flush_tasks()
File "/esphome/esphome/core/__init__.py", line 679, in flush_tasks
self.event_loop.flush_tasks()
File "/esphome/esphome/coroutine.py", line 246, in flush_tasks
next(task.iterator)
File "/esphome/esphome/__main__.py", line 184, in wrapped
await coro(conf)
File "/config/esphome/Components/st7789/display.py", line 68, in to_code
await display.register_display(var, config)
File "/esphome/esphome/components/display/__init__.py", line 119, in register_display
await cg.register_component(var, config)
File "/esphome/esphome/cpp_helpers.py", line 56, in register_component
raise ValueError(
ValueError: Component ID lcd was not declared to inherit from Component, or was registered twice. Please create a bug report with your configuration.
This is my device definition:
esphome:
platform: ESP32
board: nodemcu-32s
external_components:
# use all components from a local folder
- source:
type: local
path: Components
# Example configuration entry
debug:
# Enable logging
logger:
level: debug
# Enable Home Assistant API
api:
ota:
password: "***"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Growtent-03 Fallback Hotspot"
password: "***"
captive_portal:
i2c:
sda: GPIO21
scl: GPIO22
scan: true
setup_priority: -100.0
- platform: htu21d
temperature:
name: "Growtent-03 Temperature"
filters:
- offset: -1.7
humidity:
name: "Growtent-03 Humidity"
filters:
- calibrate_linear:
method: least_squares
datapoints:
# Map 0.0 (from sensor) to 1.0 (true value)
- 27.1 -> 31.8
- 48.5 -> 52
update_interval: 10s
switch:
- platform: gpio
pin: GPIO5
inverted: true
- platform: gpio
pin: GPIO15
inverted: true
name: "Growtent-03 Humidifier"
spi:
clk_pin: GPIO18
mosi_pin: GPIO23
font:
- file: "fonts/Lato-Medium.ttf"
display:
- platform: st7789
backlight_pin: GPIO13
cs_pin: GPIO12
dc_pin: GPIO33
reset_pin: GPIO32
width: 240
height: 240
lambda: |-
if (id(htu_component)->is_failed())
id(bus_a)->setup();
App.reboot();
auto red = Color(255, 0, 0);
auto blue = Color(0, 0, 255);
it.printf(0, 0, id(lato_20), "IP: %s", id(wificomp).get_ip_address().str().c_str());
//it.printf(0, 30, id(lato_20), red, "Temperature: %.1f°C", id(temperature).state);
//it.printf(0, 50, id(lato_20), blue, "Humidity: %.1f%%", id(humidity).state);
// Draw the graph at position [x=10,y=20]
it.graph(0, 25, id(multi_temperature_graph), my_yellow);
it.legend(0, 175, id(multi_temperature_graph), my_yellow);
graph:
# Show multi-trace graph
- id: multi_temperature_graph
duration: 1h
x_grid: 10min
y_grid: 5.0 # degC/div
width: 240
height: 150
legend:
name_font: lato_14
value_font: lato_14
show_values: 'BESIDE'
show_lines: true
show_units: true
width: 240
height: 65
border: true
traces:
- sensor: temperature
line_type: DASHED
line_thickness: 2
color: my_red
- sensor: humidity
line_type: SOLID
line_thickness: 3
color: my_blue
color:
- id: my_red
red: 100%
green: 0%
blue: 0%
- id: my_green
red: 0%
green: 100%
blue: 0%
- id: my_blue
red: 0%
green: 0%
blue: 100%
- id: my_yellow
red: 100%
green: 100%
blue: 0%
interval:
- interval: 5s
then:
- component.update: lcd
Any help or insight as to why it does not build anymore would be appreciated.
Thanks,
