Hello there,
i’ve configured my HA with maria db and influx db. See the configuration.yaml below.
recorder:
db_url: mysql://homeassistant:homeassistant@core-mariadb/homeassistant?charset=utf8mb4
#Influxdb
influxdb:
host: a0d7b954-influxdb
port: 8086
database: homeassistant
username: !secret influx_username
password: !secret influx_password
max_retries: 3
default_measurement: state
Now i’ve asked myself where the data is safed. I’ve created two sensors to check the DB size:
#Sensor für InfluxDB Size
- platform: influxdb
port: 8086
queries:
- name: InfluxDb DB Size
unit_of_measurement: MB
value_template: '{{ (value | float / 1024 /1024) | round(1) }}'
group_function: sum
measurement: '"monitor"."shard"'
database: _internal
where: 'time > now() - 10s'
field: diskBytes
#Sensor für MariaDB Size
- platform: sql
queries:
- name: DB size
query: "SELECT table_schema AS 'db_name', ROUND(SUM( data_length + index_length ) / 1024 / 1024, 2) AS 'size_mb' FROM information_schema.TABLES WHERE table_schema='homeassistant'"
column: "size_mb"
THe measurement for influx works well, changing well etc… but for the mariadb im wondering why it dont grow. I’ve installed phpmyadmin and tried to check the database ( SELECT * FROM states
) gives me a growing numer of entries. but when i fire the SQL statemant from the sensor i always get the same number:
so the entries in the “states” table are growing but the database size is not?
Any suggestions here ?
Thank you for your participation
