I’m quite new to home assistant.
I’m trying to maintain a temperature of 21,5 degrees Celsius with an airconditioner.
I have the following actions to lower or up the set_temperature by 1 degree when the target temperature on an external temperature sensor is reached (these work):
temperature: |
{{ state_attr(‘climate.ac_woonkamer’,‘temperature’) - 1 }}
entity_id: climate.ac_woonkamer
action: climate.set_temperature
temperature: |
{{ state_attr(‘climate.ac_woonkamer’,‘temperature’) + 1 }}
What I can’t get to work is the following:
trigger: numeric_state
entity_id:
- climate.nefit
for:
hours: 0
minutes: 5
seconds: 0
above: 21.5
attribute: current_temperature
It should be so easy, but the trigger just doesn’t work.
Can someone point me in the right direction?
