Stack-In-Card: Drop-in replacement for vertical-stack-in-card
does styling work the same as with vertical-stack-in-card?
This following code produces this:
- type: custom:mod-card # robovac
  style: |
    ha-card {
      height: 115px;
      background-color: var(--primary-background-color);
      border-radius: 15px;
      box-shadow:
        {% if is_state('sun.sun', 'above_horizon') %}
          -4px -4px 4px 0 rgba(255,255,255,.5),4px 4px 4px 0 rgba(0,0,0,.03);
          -4px -4px 4px 0 rgba(50, 50, 50,.5),4px 4px 4px 0 rgba(0,0,0,.15);
  card:
    type: custom:stack-in-card
    mode: vertical
    cards:
      - type: entities
        entities:
          - entity: vacuum.robovac
            type: custom:multiple-entity-row
            show_state: false
            entities:
              - attribute: status
              - attribute: battery_level
                unit: '%'
              - entity: counter.vacuum_counter
        style: |
          ha-card {
            height: 70px;
      - type: horizontal-stack
        cards:
          - type: custom:button-card
            color: auto
            icon: mdi:play
            show_name: false
            tap_action:
              action: call-service
              service: vacuum.turn_on
              service_data:
                entity_id: vacuum.robovac
            color: auto
            icon: mdi:pause
            show_name: false
            tap_action:
              service: vacuum.pause
              service_data:
            color: auto
            icon: mdi:broom
            show_name: false
            tap_action:
              service: vacuum.clean_spot
              service_data:
            color: auto
            icon: mdi:map-marker
            show_name: false
            tap_action:
              service: vacuum.locate
              service_data:
            color: auto
            icon: mdi:home-map-marker
            show_name: false
            tap_action:
              service: vacuum.return_to_base
              service_data:
Edit: Oh got it… mod-card is no longer needed :slight_smile:
Edit 2: got it to work on this example but this config fails:
            - type: custom:stack-in-card
              style: |
                ha-card {
                  box-shadow:
              mode: vertical
              cards:
                - type: glance
                  title: Home Assistant
                  columns: 7
                  show_name: false
                  entities:
                    - entity: sensor.count_automations
                      icon: mdi:play-circle
                    - entity: sensor.count_binary_sensors
                      icon: mdi:transition-masked
                    - entity: sensor.count_lights
                      icon: mdi:lightbulb
                    - entity: sensor.count_scripts
                      icon: mdi:script-text
                    - entity: sensor.count_sensors
                      icon: mdi:counter
                    - entity: sensor.count_switches
                      icon: mdi:toggle-switch
                    - entity: sensor.count_zones
                - type: entities
                  show_header_toggle: false
                  entities:
                    - entity: sensor.potential_breaking_changes
                      icon: mdi:alert-circle
                    - entity: input_select.log_level
Thanks for the new card!
If not using HACS, where can we find that stack-in-card.js?
I looked at that page but forgot to check releases button/section. Got it now.
Great! Replaced the old vertical-in-card and working perfectly. Thanks!
@RomRider I got a question, is it possible to have the “divider” working inside the stack-in-card?
My code:
people:
  card:
    mode: vertical
    cards:
      - type: custom:decluttering-card
        template: title
        variables:
          - title: People
        template: andrea
      - type: divider
The error:
Also, I am seeing in the console a huge amount of errors like this one:
hui-stack-card.ts:109 Uncaught TypeError: Cannot read property 'replaceChild' of null
    at HTMLElement.value (hui-stack-card.ts:109)
    at HTMLElement.t.addEventListener.once (hui-stack-card.ts:97)
    at r (fire_event.ts:76)
    at create-element-base.ts:94
value @ hui-stack-card.ts:109
t.addEventListener.once @ hui-stack-card.ts:97
r @ fire_event.ts:76
(anonymous) @ create-element-base.ts:94
Promise.then (async)
a @ create-element-base.ts:92
l @ create-element-base.ts:154
Tt @ create-card-element.ts:53
value @ hui-stack-card.ts:89
(anonymous) @ hui-stack-card.ts:54
value @ hui-stack-card.ts:53
s @ create-element-base.ts:61
l @ create-element-base.ts:158
_createCard @ stack-in-card.js:784
async function (async)
setConfig @ stack-in-card.js:758
a @ create-element-base.ts:80
l @ create-element-base.ts:131
_createCard @ decluttering-card.js:743
setConfig @ decluttering-card.js:739
(anonymous) @ layout-card.js:1
u @ layout-card.js:1
build_card @ layout-card.js:1
build_cards @ layout-card.js:1
updated @ layout-card.js:1
performUpdate @ updating-element.ts:720
_enqueueUpdate @ updating-element.ts:653
_enqueueUpdate @ updating-element.ts:640
_requestUpdate @ updating-element.ts:605
initialize @ updating-element.ts:449
initialize @ lit-element.ts:146
A @ updating-element.ts:438
V @ lit-element.ts:61
p @ layout-card.js:1
s @ create-element-base.ts:56
value @ hui-panel-view.ts:55
value @ hui-panel-view.ts:34
performUpdate @ updating-element.ts:704
i @ hui-panel-view.ts:16
value @ hui-root.ts:709
(anonymous) @ hui-root.ts:79
(anonymous) @ debounce.ts:22
setTimeout (async)
(anonymous) @ debounce.ts:27
handleEvent @ parts.ts:505
__boundHandleEvent @ parts.ts:463
r @ card-mod.js:1
(anonymous) @ card-mod.js:1
n @ card-mod.js:1
3hui-stack-card.ts:109 Uncaught TypeError: Cannot read property 'replaceChild' of null
setTimeout (async)
a @ layout-card.js:1
requestUpdate @ updating-element.ts:623
updateSize @ layout-card.js:1
firstUpdated @ layout-card.js:1
performUpdate @ updating-element.ts:718
setTimeout (async)
r @ card-mod.js:1
n @ card-mod.js:1
setTimeout (async)
setTimeout (async)
r @ card-mod.js:1
n @ card-mod.js:1
Thanks for your work :slight_smile:
hui-stack-card is not me, it’s a core element (vertical-stack or horizontal-stack). Not much I can do about it.
I’ll add the divider support though, thanks for letting me know :slight_smile:
Edit: type: divider is not valid in a standard vertical-stack (and this is what I use to wrap all your cards).
Thanks :slight_smile:
That’s odd, that error started now that I’ve added your stack-in-card, I thought it was related
Not sure to understand what fails. Could detail the problem please?
You’ll have to replace your divider with:
          - type: entities
            entities:
              - type: divider
But there another problem by doing that which I’m trying to fix right now :slight_smile:
Oh I see, thanks for the time you’re taking to help me with this
Sorry for being vague… the styling is only applied on the first part (glance-card) of the card. The entities part should be in the same background-colour as the glance card
Right, I’ve seen the same thing on my side. entities card do not keep the style. I’m looking into this :slight_smile:
how come type: divider isn’t valid? Or, maybe the better question would be: how come the the vertical-stack-in-card didn’t throw an error on this? much friendlier to use the shorthand notation…
maybe you are willing to think of that finding a solution to the problem your trying to fix now :wink:
btw, your current solution doesn’t throw an error in the inspector at all, and is working just perfectly as far as we can see here.
trying to keep the background of the markdown card in the stack wont work, am I misunderstanding the --keep-background styles setting?
    cards:
      - type: markdown
        styles:
          card:
            - --keep-background: 'true'
        style: |
          ha-card {
            background: url('/local/images/alarm_bell.png');
            background-size: cover;
        content: >
          # <font color={{'green' if states('sensor.next_alarm') == 'Not set' else 'crimson'}}>Next alarm</font>
          <font color={{'green' if states('sensor.next_alarm') == 'Not set' else 'crimson'}}>{{states('sensor.next_alarm_text')}}</font>
      - type: entities
#        title: Next alarm
        entities:
          - sensor.next_alarm_text
          - sensor.time_until_next_alarm
          - sensor.number_of_days_next_alarm
          - sensor.next_alarm_day
          - sensor.next_alarm
          - entity: script.say_next_alarm
            action_name: Say
          - entity: script.say_next_alarm_greet
            action_name: Greet
I won’t find a solution, as instead of redefining a complete new element I leverage HA’s core elements (vertical-stack and horizontal-stack) and they natively don’t support divider as a child element.
        style: |
          ha-card {
            --keep-background: 'true';
Of course I tried that before asking, sorry, should have mentioned. It doesn’t work however…It show what I posted above, and no error in the inspector
for reference, this is what vertical-stack-in-card makes of it:
funny enough, it doesnt complain about the --keep-background which I forgot to take out
@RomRider Great that you took over the card. I’ve read your comments over at GitHub. :slight_smile: Thanks!
When you’re done with all the “moving”, could you please make an example for an update from vertical-stack-in-card to stack-in-card. Oh, and it would be great, if you could rename and clean the forked repository. :slight_smile:
Thanks for taking action! :slight_smile:
That’s easy enough
Change every instance of “vertical-stack-in-card” to “stack-in-card”
That’s it :slight_smile:
Default will be vertical anyway, if you wanna be “precise”, you can add just underneath
“mode: vertical”
Hope this help :slight_smile:
EDIT: Just to clarify, you need to intall the card and add it to the resources first :wink:
Could you try without the quotes please?
--keep-background: true;
