A replacement for vertical-stack-in-card and horizontal-stack-in-card with some more features.
It allows to group multiple cards into one card without the borders. By default, it will stack everything vertically.
Options
If a card inside the stack has the --keep-background CSS style defined, it will not replace the background. This is usefull for button-card for example. You can also define this CSS variable by using card-mod .
Name
Type
Requirement
Description
Default
type
string
Required
custom:stack-in-card
title
string
Optional
Header of the card
mode
string
Optional
vertical or horizontal stack
vertical
cards
object
Required
The cards you want to embed
none
Example
Simple Example
- type: custom:stack-in-card
title: My Stack In Card
mode: vertical
cards:
- type: horizontal-stack
cards:
- type: button
entity: sun.sun
- type: button
entity: sun.sun
- type: vertical-stack
cards:
- type: entities
entities:
- sun.sun
Example with button-card to keep the background
This will keep the background of the button even if stacked:
mode: vertical
cards:
- type: custom:button-card
entity: sun.sun
color_type: card
styles:
card:
- --keep-background: 'true'
Installation
Use HACS or follow this guide
resources:
url: /local/stack-in-card.js
type: module
SeLLeRoNe
(Andrea Iannucci)
March 21, 2020, 12:12pm
2
Updating the HACS Repos to find it
Knapoc
March 21, 2020, 12:13pm
3
does styling work the same as with vertical-stack-in-card?
This following code produces this:
- type: custom:mod-card # robovac
style: |
ha-card {
height: 115px;
background-color: var(--primary-background-color);
border-radius: 15px;
box-shadow:
{% if is_state('sun.sun', 'above_horizon') %}
-4px -4px 4px 0 rgba(255,255,255,.5),4px 4px 4px 0 rgba(0,0,0,.03);
{% else %}
-4px -4px 4px 0 rgba(50, 50, 50,.5),4px 4px 4px 0 rgba(0,0,0,.15);
{% endif %}
card:
mode: vertical
cards:
- type: entities
entities:
- entity: vacuum.robovac
type: custom:multiple-entity-row
show_state: false
entities:
- attribute: status
- attribute: battery_level
unit: '%'
- entity: counter.vacuum_counter
style: |
ha-card {
height: 70px;
cards:
color: auto
icon: mdi:play
show_name: false
tap_action:
action: call-service
service: vacuum.turn_on
service_data:
entity_id: vacuum.robovac
color: auto
icon: mdi:pause
show_name: false
tap_action:
service: vacuum.pause
service_data:
color: auto
icon: mdi:broom
show_name: false
tap_action:
service: vacuum.clean_spot
service_data:
color: auto
icon: mdi:map-marker
show_name: false
tap_action:
service: vacuum.locate
service_data:
color: auto
icon: mdi:home-map-marker
show_name: false
tap_action:
service: vacuum.return_to_base
service_data:
Edit: Oh got it… mod-card is no longer needed
Edit 2: got it to work on this example but this config fails:
style: |
ha-card {
box-shadow:
{% else %}
{% endif %}
mode: vertical
cards:
- type: glance
title: Home Assistant
columns: 7
show_name: false
entities:
- entity: sensor.count_automations
icon: mdi:play-circle
- entity: sensor.count_binary_sensors
icon: mdi:transition-masked
- entity: sensor.count_lights
icon: mdi:lightbulb
- entity: sensor.count_scripts
icon: mdi:script-text
- entity: sensor.count_sensors
icon: mdi:counter
- entity: sensor.count_switches
icon: mdi:toggle-switch
- entity: sensor.count_zones
- type: entities
show_header_toggle: false
entities:
- entity: sensor.potential_breaking_changes
icon: mdi:alert-circle
- entity: input_select.log_level
AhmadK
(akasma74)
March 21, 2020, 12:16pm
4
Thanks for the new card!
If not using HACS, where can we find that stack-in-card.js?
AhmadK
(akasma74)
March 21, 2020, 12:20pm
6
I looked at that page but forgot to check releases button/section. Got it now.
McGiverGim
(Míguel Ángel Mulero Martínez)
March 21, 2020, 12:24pm
7
Great! Replaced the old vertical-in-card and working perfectly. Thanks!
SeLLeRoNe
(Andrea Iannucci)
March 21, 2020, 1:10pm
8
@RomRider I got a question, is it possible to have the “divider” working inside the stack-in-card?
My code:
people:
card:
mode: vertical
cards:
- type: custom:decluttering-card
template: title
variables:
- title: People
template: andrea
- type: divider
The error:
Also, I am seeing in the console a huge amount of errors like this one:
hui-stack-card.ts:109 Uncaught TypeError: Cannot read property 'replaceChild' of null
at HTMLElement.value (hui-stack-card.ts:109)
at HTMLElement.t.addEventListener.once (hui-stack-card.ts:97)
at r (fire_event.ts:76)
at create-element-base.ts:94
value @ hui-stack-card.ts:109
t.addEventListener.once @ hui-stack-card.ts:97
r @ fire_event.ts:76
(anonymous) @ create-element-base.ts:94
Promise.then (async)
a @ create-element-base.ts:92
l @ create-element-base.ts:154
Tt @ create-card-element.ts:53
value @ hui-stack-card.ts:89
(anonymous) @ hui-stack-card.ts:54
value @ hui-stack-card.ts:53
s @ create-element-base.ts:61
l @ create-element-base.ts:158
_createCard @ stack-in-card.js:784
async function (async)
setConfig @ stack-in-card.js:758
a @ create-element-base.ts:80
l @ create-element-base.ts:131
_createCard @ decluttering-card.js:743
setConfig @ decluttering-card.js:739
(anonymous) @ layout-card.js:1
u @ layout-card.js:1
build_card @ layout-card.js:1
build_cards @ layout-card.js:1
updated @ layout-card.js:1
performUpdate @ updating-element.ts:720
_enqueueUpdate @ updating-element.ts:653
_enqueueUpdate @ updating-element.ts:640
_requestUpdate @ updating-element.ts:605
initialize @ updating-element.ts:449
initialize @ lit-element.ts:146
A @ updating-element.ts:438
V @ lit-element.ts:61
p @ layout-card.js:1
s @ create-element-base.ts:56
value @ hui-panel-view.ts:55
value @ hui-panel-view.ts:34
performUpdate @ updating-element.ts:704
i @ hui-panel-view.ts:16
value @ hui-root.ts:709
(anonymous) @ hui-root.ts:79
(anonymous) @ debounce.ts:22
setTimeout (async)
(anonymous) @ debounce.ts:27
handleEvent @ parts.ts:505
__boundHandleEvent @ parts.ts:463
r @ card-mod.js:1
(anonymous) @ card-mod.js:1
n @ card-mod.js:1
3hui-stack-card.ts:109 Uncaught TypeError: Cannot read property 'replaceChild' of null
setTimeout (async)
a @ layout-card.js:1
requestUpdate @ updating-element.ts:623
updateSize @ layout-card.js:1
firstUpdated @ layout-card.js:1
performUpdate @ updating-element.ts:718
setTimeout (async)
r @ card-mod.js:1
n @ card-mod.js:1
setTimeout (async)
setTimeout (async)
r @ card-mod.js:1
n @ card-mod.js:1
Thanks for your work
hui-stack-card is not me, it’s a core element (vertical-stack or horizontal-stack). Not much I can do about it.
I’ll add the divider support though, thanks for letting me know
Edit: type: divider is not valid in a standard vertical-stack (and this is what I use to wrap all your cards).
SeLLeRoNe
(Andrea Iannucci)
March 21, 2020, 1:43pm
10
That’s odd, that error started now that I’ve added your stack-in-card, I thought it was related
Not sure to understand what fails. Could detail the problem please?
You’ll have to replace your divider with:
- type: entities
entities:
- type: divider
But there another problem by doing that which I’m trying to fix right now
SeLLeRoNe
(Andrea Iannucci)
March 21, 2020, 1:54pm
13
Oh I see, thanks for the time you’re taking to help me with this
Knapoc
March 21, 2020, 2:03pm
14
Sorry for being vague… the styling is only applied on the first part (glance-card) of the card. The entities part should be in the same background-colour as the glance card
Right, I’ve seen the same thing on my side. entities card do not keep the style. I’m looking into this
how come type: divider isn’t valid? Or, maybe the better question would be: how come the the vertical-stack-in-card didn’t throw an error on this? much friendlier to use the shorthand notation…
maybe you are willing to think of that finding a solution to the problem your trying to fix now
btw, your current solution doesn’t throw an error in the inspector at all, and is working just perfectly as far as we can see here.
trying to keep the background of the markdown card in the stack wont work, am I misunderstanding the --keep-background styles setting?
cards:
- type: markdown
styles:
card:
style: |
ha-card {
background: url('/local/images/alarm_bell.png');
background-size: cover;
content: >
# <font color={{'green' if states('sensor.next_alarm') == 'Not set' else 'crimson'}}>Next alarm</font>
<font color={{'green' if states('sensor.next_alarm') == 'Not set' else 'crimson'}}>{{states('sensor.next_alarm_text')}}</font>
- type: entities
# title: Next alarm
entities:
- sensor.next_alarm_text
- sensor.time_until_next_alarm
- sensor.number_of_days_next_alarm
- sensor.next_alarm_day
- sensor.next_alarm
- entity: script.say_next_alarm
action_name: Say
- entity: script.say_next_alarm_greet
action_name: Greet
I won’t find a solution, as instead of redefining a complete new element I leverage HA’s core elements (vertical-stack and horizontal-stack) and they natively don’t support divider as a child element.
style: |
ha-card {
--keep-background: 'true';
Of course I tried that before asking, sorry, should have mentioned. It doesn’t work however…It show what I posted above, and no error in the inspector
for reference, this is what vertical-stack-in-card makes of it:
funny enough, it doesnt complain about the --keep-background which I forgot to take out
paddy0174
(Patrick)
March 21, 2020, 3:43pm
20
@RomRider Great that you took over the card. I’ve read your comments over at GitHub. Thanks!
When you’re done with all the “moving”, could you please make an example for an update from vertical-stack-in-card to stack-in-card. Oh, and it would be great, if you could rename and clean the forked repository.
Thanks for taking action!
