Stack in Cards flash on first load
I’m trying to create a nicer dashboard with stack in cards and cardmod.
The first time the page loads in a browser the cards all seem to “flash” into place.
Is this normal behavior or am i doing something wrong?
In the gif below you can see what i mean.
HA - Problem with Cardmod or StackInCard
Below you can see the code i use for the card and also the theme i’m using. (Not sure if the theme has anything to do with it?!?) This card is put together with code i found in forums and on youtube channels. I don’t have much experience with CSS.
I’m using the margin bit a lot just to get the buttons a bit closer together, otherwise all the elements take up too much space.
If there is a better way of achieving a similar result i’m all ears. But i would at least like to get rid of the flashing if possible.
Main reason i want to get rid of it is that i want to start using some as those cards as popup cards via browsermod, but everytime the popup shows up you have the same behavior. If it was just on the main screen i could live with it doing it once while loading.
Any help would be greatly appreciated
Stack in Card Code:
type: custom:stack-in-card
cards:
  - type: horizontal-stack
    cards:
      - type: custom:button-card
        styles:
          name:
            - font-weight: bold
            - font-size: 30px
            - justify-self: start
            - color: silver
        tap_action:
          action: navigate
          navigation_path: /layout-card/buttontest
        card_mod:
          style: |
            ha-card
               background: trannsparent;
               margin: 25px 0px 0px 20px;
      - type: markdown
        content: |-
          <font size= 5px color= silver> <center><b>
          {{state_attr("weather.home_hourly","temperature")}}°C
          </center></b></font> </a>
        card_mod:
          style: |
            ha-card
              {margin: -10px 0px 0px 110px;}
  - type: grid
    columns: 6
    square: false
    cards:
        primary: ''
        secondary: ''
        icon: ''
        card_mod:
          style: |
            ha-card
              {margin: -25px 0px 10px 0px;}
        primary: ''
        secondary: ''
        icon: ''
        card_mod:
          style: |
            ha-card
      - type: custom:mushroom-light-card
        entity: light.porch_lights
        secondary_info: none
        layout: vertical
        card_mod:
          style: |
            ha-card
        entity: light.downstairs_lights
        layout: vertical
        card_mod:
          style: |
            ha-card
              {margin: -25px -30px 10px 0px;}
  - type: custom:mushroom-chips-card
    chips:
      - type: entity
        entity: binary_sensor.downstairs_motion
        content_info: none
    alignment: center
    card_mod:
      style: |
        ha-card
          {margin: -5px 0px 10px 0px;}
Theme:
# iOS Dark Mode Theme - dark-blue
ios-dark-mode-dark-blue-alternative:
  # Global
  background-image: "center / cover no-repeat fixed url('/hacsfiles/themes/ios-themes/homekit-bg-dark-blue.jpg')"
  lovelace-background: var(--background-image)
  primary-color: "#ff9f09"  # from Apple systemOrange dark mode
  light-primary-color: "#B6B6C1"  # (icons on left menu) (light: systemGray5 from iOS dark mode, dark: XXX)
  primary-background-color: "#2c2c2e"  # systemGray5 dark mode
  secondary-background-color: rgba(25, 25, 25, 0.9)
  divider-color: rgba(152, 152, 157, 0.3)  # from Apple systemGray dark mode
  accent-color: rgba(255, 159, 9, 1)
  # Text
  primary-text-color: "#FFF"
  secondary-text-color: "#d3d3d3"
  text-primary-color: "#FFF"
  disabled-text-color: "#555"  # XXX: https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/2
  text-dark-color: "#FFF"
  # Sidebar Menu
  sidebar-background-color: var(--primary-background-color)
  sidebar-icon-color: var(--light-primary-color)
  sidebar-text-color: "#F1F1F1"
  sidebar-selected-background-color: var(--primary-background-color)
  sidebar-selected-icon-color: "#FFF"  # (light: systemGray5 from iOS light mode, dark: XXX)
  sidebar-selected-text-color: var(--sidebar-selected-icon-color)
  # States and Badges
  state-icon-color: "#FFF"
  state-icon-active-color: "#FFF"  # or make light icons yellow when active: rgba(255, 214, 10, 1)
  state-icon-unavailable-color: var(--disabled-text-color)
  paper-item-icon-active-color: "#FFF"  # see https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/30
  # Sliders
  paper-slider-knob-color: "#FFFFFF"
  paper-slider-knob-start-color: var(--paper-slider-knob-color)
  paper-slider-pin-color: var(--paper-slider-knob-color)
  paper-slider-active-color: "#0984ff"  # from Apple systemBlue dark mode
  paper-slider-secondary-color: var(--paper-slider-knob-color)
  paper-slider-container-color: rgba(255, 255, 255, 0.5)
  paper-slider-font-color: "#000"
  ha-slider-background: none !important
  # Labels
  label-badge-background-color: "#23232E"
  label-badge-text-color: "#F1F1F1"
  label-badge-red: rgba(255, 159, 9, 0.7)  # from Apple systemOrange dark mode
  # Cards
  card-background-color: var(--secondary-background-color)  # Unused entities table background
  paper-listbox-background-color: var(--primary-background-color)
  ha-card-border-radius: 20px
  ha-card-background: rgba(10, 10, 10, 0.4)
  paper-card-background-color: var(--ha-card-background)
  ha-card-border-width: 0  # https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/82#event-7732695357
  # Toggles
  paper-toggle-button-checked-button-color: "#484848"
  paper-toggle-button-checked-bar-color: "#484848"
  paper-toggle-button-unchecked-button-color: var(--paper-toggle-button-checked-button-color)
  paper-toggle-button-unchecked-bar-color: var(--disabled-text-color)
  # Table row
  table-row-background-color: var(--primary-background-color)
  table-row-alternative-background-color: var(--secondary-background-color)
  # Switches
  switch-checked-color: "#30d257"  # XXX: remove when https://github.com/home-assistant/home-assistant-polymer/pull/4203 is in HA
  switch-checked-track-color: "#30d158"  # from Apple systemGreen dark mode
  switch-checked-button-color: "#FFF"
  # Other
  paper-dialog-background-color: rgba(55, 55, 55, 0.8)  # e.g., background of more-info
  paper-item-icon-color: white  # also should mini-media-player icon white (but doesn't work by itself)
  more-info-header-background: rgba(25, 25, 25, 0.5)
  lumo-body-text-color: var(--primary-text-color)  # see https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/42
  app-header-background-color: rgba(48, 69, 124, 0.4)
  markdown-code-background-color: "#464646"
  code-editor-background-color: "#161616"
  # Custom
  mcg-title-letter-spacing: .15em
  mini-media-player-base-color: white
  mini-media-player-icon-color: white
  # Added for https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/72
  # TODO: add description for lines below. Suggested in https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/72
  input-ink-color: var(--primary-text-color)
  input-fill-color: transparent
  input-disabled-fill-color: transparent
  input-label-ink-color: var(--primary-text-color)
  input-disabled-ink-color: var(--disabled-text-color)
  input-dropdown-icon-color: var(--primary-text-color)
  input-idle-line-color: var(--secondary-text-color)
  input-hover-line-color: var(--secondary-text-color)
  codemirror-property: var(--accent-color)
  #browser_mod.popup
  #dialog-backdrop-filter: blur(2em) brightness(0.75)
  popup-background-color: rgba(34,38,39,0.9)
  popup-border-width: 1px
  popup-border-radius: 1em
  tablet-popup-header-color: rgba(200, 218, 222, 0.05)
  tablet-popup-content-padding: 1.4em 2.2em 1.6em 1.5em
  tablet-popup-button-padding: 0.1em 2em 1.8em 2em
  tablet-popup-border-style: 1.5px solid rgba(0,0,0,0.2)
digging up this post to see if there is anything that changed, I see the same behavior and that is especially annoying using it on a mobile device as the cards re-load every time I open the a App
Did you find any solution? I also facing same issue.
I have the same issue with the companion app, but only in dark mode. It’s a shame - the card_mod edits look great but the initial flash (for the initial load) detracts somewhat. It would be great if someone can find a solution
Did you find any solution???
