This is Blueprint will adjust your climate entity thermostat to 1°(adjustable) above the current temp and keep it there until a max temp. This keeps my stage 2 heat source off during chosen times. Only runs within the time period you state. There is also facility to control based on zone occumation and a roll-your-own reason.
Changelog
- 2024-06-08: Blueprint Input Sections for enhanced Descriptions.
- (Documentation change 2-7-2024 to add License notice. Changes only to Descriptions.)
- 2024-01-19: Add Trigger to make it more likely to run after restarting automations.
- Add variables - clean-up action code - generate values once instead of multiple times.
- Clarify some descriptions.
- 2023-12-02:
First release!
About this blueprint
Type of blueprint: AUTOMATION
What if I am having problems getting it going?
You can contact me for help, see the links below.
Why do I need this?
I use this BluePrint to set my Pellet stove on in the morning without triggering my stage 2 oil furnace. Without this when the thermostat setbaco adjust from the overniight 55° setting to the morning 70 degree setting, the jump of more than 2° between actual and set forced the oil stove to start. Using this, only the wood burns.
I set this up to use the current temperature ans the temperature set point in e standard climate entity. You may have to adjust things if you want to run it different.
There is an optional ability, defaulting to false (off), to prevent the BluePrint from triggering should a zone you pick be unoddupied.
HA ZONES LINK
License Notice:
Copies of the original Blueprint that were converted via the ‘Take Control’ feature or other means are officially not supported by me.
I may or may not be able to support you when you have a problem after you make changes to my code, as some of the code is no longer mine.
I & my license also require attribution as a link back to the original should you use this code in your own creation.
Here is a link to my license & the original github post expected to be followed & referenced as attribution should you use this code elsewhere.
Configuration
Requirements
- An HA climate entity that can monitor temperature and provide the current_temperature be the entity to be controlled.
Input fields
people2monitor/name: Person or People to follow
Select the Person you want this BP to trigger
on for this action. Multiples are allowed.
climate_e/name: Room Thermostat
The Climate device, thermostat, that you are ramping.
maxTemp/name: Goal Temperature
If it is at least this, go no warmer.
rampRate/name: Degrees above actual
Keep set point this above actual
interval/ name: Hold Period
Set this delay between thermostat temp setting events.
If it changes the goal set temp, it waits this long before it rechecks.
Basically this rate limits stuff.
ramp_start_time/name: Time of day ramp should start
Set this for the time of day you want the ramp function to be enabled.
weekday/name: Day of the week to use the Automation
Control temp on these days with this automation.
occ_test/name: Enable the Occupancy test?
This BluePrind can take into consideration if a zone is occupied.
To enable this feature, select yes.
To ignore this feature select no.
t_zone/name: Zone to monitor for occupancy
If you said yes above, then you enter the zome to monitoe here.
Default zone is home. Change to another zone if you want to.
If you said no above, this section has no effect on your BluePrint.
additional_conditions/name: Additional conditions
Extra conditions you may want to add to this automation
(Example: It is the heating season, etc.)
Troubleshooting tip
If you are troubleshooting and you want to see more traces back when doing so, here is a TIP I’ve found.
Manually edit the automation created with the ui editor (or manually with a text editor) and add the following to have this automation contain 10 traces instead of the normal 5. Then if the automation is triggering often, you can see the last 10 traces to help you decide what the issue is.
HA Docs on this here.
trace:
stored_traces: 10
Version Updates
Updates will be published on my GIT repository with the rest of my Home Assistant Blueprint collection.
There is not an official version control system for Blueprints. However I have found something that comes pretty close. It is not perfect, but for MOST Blueprints, it does just fine. I encourage you to check this script out and use it to easily check if I have updated this blueprint.
koter84 Blueprint Update Script
Please Click the
at the end of this top Post if you find this Useful
Software to Download
HA link to download blueprint:
Direct link to download Blueprint: https://github.com/SirGoodenough/HA_Blueprints/blob/master/Automations/Stage_1_Temperature_Control.yaml
All My Blueprints
https://github.com/SirGoodenough/HA_Blueprints/blob/master/README.md
Contact Links or see my other work
What are we Fixing Today Homepage / Website: https://www.WhatAreWeFixing.Today/
Channel Link URL: (WhatAreWeFixingToday) https://bit.ly/WhatAreWeFixingTodaysYT
Discord Guild: (Sir_Goodenough#9683) WhatAreWeFixingToday?
If you want to support me
Buy me Coffee: https://www.buymeacoffee.com/SirGoodenough
PayPal one-off donation link: PayPal.Me
#WhatAreWeFixingToday
#SirGoodEnough
