Staircase automation... a concept
Im planing to get Govee RGBCCT. where I can segment each step in the same LED and use whatever mode I want and can use vibration. sensor to trigger it…any better implementation ?
Most setups go for 2-3 motion sensors under the hand rail to segment the sections from what I have seen for projects like this to make it work. Make sure its a sensor that you can keep plugged into power so that you don’t have worry about swapping batteries once you have set them up else look into battery eliminators for the ones you go for.
Also did we not link you a how to in another thread when you were asking about the hardware for this?
Yes but the video was so complex and he didn’t share the code at all
I can see Govee is better idea, using motion sensor can be tricky for my design ( glass handrail )
