Stand Alone Climate Control
I am moving my HA environment from a centralised command and control on a raspberry pi to a distributed ESPHome setup (HA on a virtual machine, with control via ESPHome on ESP8266 and ESP32 units). Part of that journey means moving functionality from within HA automations and YAML files to ESPHome configurations. One such area is the climate control I currently use…
I found this code to setup a climate control on ESPHome…
climate:
  - platform: thermostat
    sensor: my_temperature_sensor
    default_target_temperature_high: 22 °C
    cool_action:
      - switch.turn_on: air_cond
    idle_action:
      - switch.turn_off: air_cond
Which is great, but I am stuck trying to integrate the functionality from this automation code below.
alias: Open Damper
description: Open Damper Based on Outside Temperature
  - platform: numeric_state
    entity_id: sensor.esp_outside_temp
    below: '21'
  - platform: state
    entity_id: binary_sensor.ac_status
    to: 'off'
condition:
  - condition: state
    state: 'off'
  - service: switch.turn_on
    data: {}
    entity_id: switch.damperrelay
  - service: mqtt.publish
      topic: HomeAssistant/Studio/Damper/Status
      payload: '1'
mode: single
alias: Close Damper
description: ''
    above: '21'
  - platform: state
    to: 'on'
condition: []
  - service: switch.turn_off
    data: {}
      entity_id: switch.hvac_damper
      payload: '0'
mode: single
alias: Studio Fan Status
description: ''
  - platform: state
    entity_id: switch.hvac_fan
condition: []
  - choose:
      - conditions:
          - condition: state
            state: 'on'
        sequence:
              topic: HomeAssistant/Studio/Fan/Status
              payload: '1'
      - conditions:
          - condition: state
            state: 'off'
        sequence:
              payload: '0'
    default: []
mode: single
alias: Start Fan
description: Start Fan Climate Control Based on Temperature and Damper Status
  - platform: state
    to: 'on'
condition: []
  - service: climate.turn_on
      entity_id: climate.studiofan
mode: single
alias: Stop Fan
description: Stop Fan Climate Control Based on Damper Status
  - platform: state
    to: 'off'
condition: []
  - service: climate.turn_off
mode: single
The automations above were originally running on my raspberry pi, which also had the GPIO ports connected to a relay board. But since I now use a VM to host HA and ESP8266 and ESP32 to do the relay board things dont work so well.
In essence I want the ESPHome ESP8266 to be stand alone in the event HA stops working. So I want the ESPHome connected to the relay board to open and close the air damper and start the fan based on various checks (see automation examples above).
I am sure the solution is simple, and it’s just a learning curve for me… so if there’s any examples some of you have seen that I could use to guide me that would be great. Much appreciated.
Thanks, is there an editor I could use that could help me code the YAML? Something that might help me find my coding mistakes prior to loading onto the ESP8266?
The editor built into esphome does that, or use vscode.
Tried to setup the climate control but seeing weird behavior and results in the logs… Here’s the ESPHome config.
esphome:
  platform: ESP8266
  board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: !secret ota_password
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Hvac-Test Fallback Hotspot"
    password: "<PASSWORD>"
captive_portal:
status_led:
  pin: GPIO2
dallas:
  - pin: D1
    update_interval: 30s
  - platform: dallas
    address: 0x1101143025227D28
  - platform: dallas
    address: 0xE602131B13F9AA28
switch:
climate:
    sensor: in_dallas_id
    default_target_temperature_high: 21 °C
    cool_action:
      - switch.turn_on: template_swi
    idle_action:
      - switch.turn_off: template_swi
Here’s the log file entry…
[21:08:15][D][dallas.sensor:153]: 'in_temp': Got Temperature=19.9°C
[21:08:15][D][sensor:117]: 'in_temp': Sending state 19.93750 °C with 1 decimals of accuracy
[21:08:15][D][climate:369]: 'climate_id' - Sending state:
[21:08:15][D][climate:372]:   Mode: OFF
[21:08:15][D][climate:374]:   Action: OFF
[21:08:15][D][climate:392]:   Current Temperature: 19.94°C
[21:08:15][D][climate:398]:   Target Temperature: 21.00°C
[21:08:15][D][dallas.sensor:153]: 'out_temp': Got Temperature=15.8°C
[21:08:15][D][sensor:117]: 'out_temp': Sending state 15.81250 °C with 1 decimals of accuracy
I dont understand why MODE is OFF and ACTION is OFF??
Also, another unusual situation… when I am not connected to the nodemcu the blue led flashes about once every second. When I click on LOGS in the ESPHome panel the led changes to solid?
Question… I want the thermostat to only turn on the switch if several conditions are met… so I assume the checks of those conditions are placed within the thermostat sections below…
cool_action:
    idle_action:
Thanks, Mark
Haven’t received any responses to above, so not hopeful of anything on this one.
Have spent loads of time reading and learning, built a test rig and have come up with the following code. It works, but I am sure there are much more elegant ways it could be written/done?
Not a fan of the bang bang controller and would prefer an actual thermostat style with hysteresis, but at least this is a start.
Anyway, if anyone reads this and can offer some tips or suggestions that would be very much appreciated. If not, sorry for wasting your time.
esphome:
  platform: ESP8266
  board: nodemcuv2
# Enable logging
logger:
api:
ota:
wifi:
  ap:
    ssid: "Testbuild Fallback Hotspot"
    password: "<redacted>"
captive_portal:
# MQTT Interface
mqtt:
  broker: !secret mqtt_broker
  port: 1883
  keepalive: 60s
  on_message:
    - topic: GregoInc1/AirCon/Status
      payload: "1"
      qos: 0
      then:
        - switch.turn_on: ac_status
      payload: "0"
      qos: 0
      then:
        - switch.turn_off: ac_status
status_led:
  pin: GPIO2
#Temperature Sensor Pin
dallas:
  - pin: D1
#Relay switches
switch:
  - platform: gpio
    pin:
      number: D5
      inverted: True
    restore_mode: RESTORE_DEFAULT_ON
  - platform: gpio
    pin:
      number: D7
      inverted: True
    restore_mode: RESTORE_DEFAULT_OFF
  - platform: dallas
  - platform: dallas
interval:
  - interval: 30sec
    then:
      - if:
          condition:
            and:
            # Is the outside temp below 20 and the AC off
              - lambda: 'return id(out_dallas_id).state < 20;'
              - switch.is_off: ac_status
          then:
              - switch.turn_on: damper_sw
      - if:
          condition:
            or:
            # Is the outside temp above 20
              - lambda: 'return id(out_dallas_id).state > 20;'
            # Check to see if the AC is running
              - switch.is_on: ac_status
          then:
              - switch.turn_off: damper_sw
climate:
  - platform: bang_bang
    name: "Bang Bang Climate Controller"
    default_target_temperature_low: 20 °C
    cool_action:
      script.execute: control_fan
    idle_action:
script:
  - id: control_fan
    then:
    - if:
        condition:
          lambda: 'return id(in_dallas_id).state <= 20;'
        then:
          - logger.log: "The indoor sensor value is below 20!"
          - switch.turn_off: fan_sw
    - if:
        condition:
          and:
            - lambda: 'return id(in_dallas_id).state >= 22;'
        then:
          - logger.log: "The indoor sensor value is above 22!"
          - switch.turn_on: fan_sw
I will add a few more things and see how it goes on the actual esphome unit. Thanks, Mark
Have you joined the esphome discord server, it maybe better place to handle specific esphome stuff
Hi @aidbish great to hear from you, and thank for the advice/suggestion.
Honestly I haven’t explored the discord as I’ve felt this forum is possibly not as friendly as other IOT forums I have joined. I get that asking random ‘dumb’ questions can be frustrating for those experienced forum guru members, but in my opinion building/sharing the knowledge/experience is what can make a forum strong and the product grow in popularity.
For me personally I have found forums such as ESPEasy and Domoticz are friendly, share experience openly, and the gurus are incredibly generous with their time and knowledge with those of us that are dummies and were just starting out. Over time knowledge grew and those newbies became the next level of supporting the forum and newcomers.
Anyway, I guess each forum environment is different, as are the members. I am not complaining, just sharing a few comparisons/observations. I think Home Assistant and ESPHome are awesome, with so many possibilities… so the journey will continue :slight_smile:
Take care, Mark
Have made some fantastic progress thanks to the folks on the esphome discord. Thought I would share my code here on the chance it might help someone new to esphome like me.
esphome:
  platform: ESP8266
  board: nodemcuv2
  on_boot:
    - lambda: 'id(climate_id).mode = climate::CLIMATE_MODE_COOL;'
# Enable logging
logger:
api:
  reboot_timeout: 0s
ota:
wifi:
#  use_address: testbuild.local
  ap:
    ssid: "esp1_studio Fallback Hotspot"
captive_portal:
# MQTT Interface
mqtt:
  port: 1883
  keepalive: 60s
  discovery: false
  on_message:
#    - topic: HomeAssistant/AirCon/Studio/Status
      payload: "0"
      qos: 0
      then:
        - binary_sensor.template.publish:
            state: off
      payload: "1"
      qos: 0
      then:
            state: on
status_led:
  pin: GPIO2
# Studio door reed switch sensor.
binary_sensor:
  - platform: gpio
    device_class: door
    pin:
      number: D2
      mode: INPUT_PULLUP
      inverted: False
    on_press:
      - mqtt.publish:
          topic: HomeAssistant/Studio/Door/Status
          payload: "1"
      - logger.log: "Studio Door is Open"
    on_release:
      # Publish the door is closed
      - mqtt.publish:
         payload: "0"
      - logger.log: "Studio Door is Closed"
  - platform: homeassistant
    entity_id: device_tracker.galaxy_s10
    attribute: home
# AC status
    on_press:
          state: off
    on_release:
          state: on
    on_press:
      - climate.control:
          mode: 'cool'
    on_release:
      - climate.control:
          mode: 'off'
dallas:
  - pin: D1
#Relay switches
switch:
  - platform: gpio
    pin:
      number: D6
      inverted: True
  - platform: gpio
    pin:
      number: D5
      inverted: True
  # Studio Inside temperature sensor
  - platform: dallas
  # Studio Outside temperature sensor
  - platform: dallas
    on_value:
      then:
      - if:
          condition:
          then:
              # Open the damper
                  state: on
              - mqtt.publish:
                  topic: HomeAssistant/Studio/Damper/Status_Damper
                  payload: "1"
              - logger.log: "The damper and climate is active"
      - if:
          condition:
          then:
                  state: off
              - mqtt.publish:
                  payload: "0"
              - logger.log: "The damper and climate is off"
climate:
    name: "Thermostat Climate Controller"
    cool_action:
      - logger.log: "The fan is now on"
      - mqtt.publish:
          topic: HomeAssistant/Studio/Fan/Status_Fan
          payload: "1"
    idle_action:
      - logger.log: "The fan is now off"
      - mqtt.publish:
          payload: "0"
Still some way to go, but for now it works.
Hope this helps someone :slight_smile:
The code above has been running for some time now and is successfully running the ‘free cooling’ of the room i.e. sucking in cool air when the days are not so hot.
I have also been working on a setup that will activate an air conditioner on the hot days, with information coming via various other threads.
I’ve tried to get some help on the esphome discord, but no luck so far… so I thought I might try my luck here. I am close, very close… just need a bit of advice to get things completed. Here’s my YAML code… I have identified where I believe the problem is located with
esphome:
  platform: ESP32
  board: esp32doit-devkit-v1
# Enable logging
logger:
api:
ota:
  password: "************************"
wifi:
  #use_address: esp32-ir-test.local
  ap:
    ssid: "Esp32-Ir-Test Fallback Hotspot"
    password: "**************"
captive_portal:
status_led:
  pin: GPIO2
dallas:
  - pin: GPIO15
mqtt:
  port: 1883
  reboot_timeout: 0s
  keepalive: 60s
  discovery: false
# IR TRansmitter entry
remote_transmitter:
  pin: GPIO4
  carrier_duty_percent: 50%
climate:
  - platform: daikin
    supports_heat: false
    transmitter_id: ir_transmit
binary_sensor:
    on_press:
      - logger.log: "AC is ON"
      - climate.control:
          mode: 'cool'
    on_release:
      - logger.log: "AC is OFF"
      - climate.control:
          mode: 'off'
  - platform: dallas
    resolution: 12
    address: 0x2401204FD9422728
    name: "Studio AC Inside Temperature"
# Studio Temperature / Climate Control
    name: "Studio Outside Temperature"
    entity_id: sensor.studio_out_temp
    on_value:
      then:
      - if:
          condition:
              # Test if studio temperature is over 24 degrees
              - lambda: 'return id(in_ac_dallas_id).state > 24;'
          then:
                  state: on
              - mqtt.publish:
                  topic: HomeAssistant/Studio/AirCon/Status
                  payload: "1"
              - logger.log: "AC Climate Control is Active"
      - if:
          condition:
              and:
 -->          # Test if studio inside temperature is below 24 degrees
              - lambda: 'return id(in_ac_dallas_id).state < 24;
 -->          # Test if studio outside temperature is below 19 degrees'
              - lambda: 'return id(out_temp_studio).state < 19;'
          then:
                  state: off
              - mqtt.publish:
                  payload: "0"
              - logger.log: "AC Climate Control is Not Active"
And here’s the error I receive when trying to do an OTA…
Compiling /data/esp5-studio-ac/.pioenvs/esp5-studio-ac/src/main.cpp.o
/config/esphome/esp5-studio-ac.yaml:102:43: error: stray '#' in program
/config/esphome/esp5-studio-ac.yaml: In lambda function:
/config/esphome/esp5-studio-ac.yaml:102:45: error: 'Test' was not declared in this scope
*** [/data/esp5-studio-ac/.pioenvs/esp5-studio-ac/src/main.cpp.o] Error 1
========================== [FAILED] Took 4.45 seconds ==========================
Any advice or suggestions greatly appreciated :slight_smile:
So I managed to solve the problem, but it’s not the most elegant code I have seen. Just in case this might help someone here is the code…
esphome:
  platform: ESP32
# Enable logging
logger:
#  level: VERBOSE
api:
ota:
  password: "*********************"
wifi:
  ap:
    password: "******************"
captive_portal:
status_led:
  pin: GPIO2
dallas:
  - pin: GPIO15
mqtt:
  port: 1883
  reboot_timeout: 0s
  keepalive: 60s
  discovery: false
remote_transmitter:
  pin: GPIO4
climate:
  - platform: daikin
binary_sensor:
    on_press:
      then:
              - climate.control:
                  mode: 'cool'
                  target_temperature: 22°C
              - mqtt.publish:
                  payload: "1"
    on_release:
      then:
      - if:
          condition:
              - binary_sensor.is_off: out_ac_temp_status
          then:
              - climate.control:
                  mode: 'off'
              - mqtt.publish:
                  payload: "0"
  - platform: dallas
    resolution: 12
    on_value:
      then:
      - if:
          condition:
              # Is the inside temp higher than 24
              - lambda: 'return id(in_ac_dallas).state > 22;'
          then:
              # Open the damper
                  state: on
              - logger.log: "The inside temp is above 22"
          else:
                  state: off
              - logger.log: "Telling Climate to stop"
# Studio Temperature from HA
    on_value:
      then:
      - if:
          condition:
              # Is the Outside temp under 19
          then:
                  state: off
              - logger.log: "The outside temp is below 19"
      - if:
          condition:
              # Is the Outside temp over 19
              - lambda: 'return id(out_temp_studio).state > 19;'
          then:
                  state: on
              - logger.log: "The outside temp is above 19"
Not seeing any feedback which is unfortunate.
Latest version… have made a few tweaks, and this is working well. Hope this helps someone, I always found looking at other folks code helpful.
esp8266:
 board: nodemcuv2
 framework:
  version: recommended
esphome:
  on_boot:
# Enable logging
logger:
api:
  reboot_timeout: 0s
ota:
wifi:
  ap:
    password: "redacted"
captive_portal:
# MQTT Interface
mqtt:
  port: 1883
  reboot_timeout: 0s
  keepalive: 60s
  discovery: false
  on_message:
    - topic: HomeAssistant/Studio/Aircon/Status
      payload: "OFF"
      qos: 0
      then:
            state: off
        - logger.log: "The AC is OFF"
      payload: "ON"
      qos: 0
      then:
            state: on
        - logger.log: "The AC is ON"
status_led:
  pin: GPIO2
binary_sensor:
# AC status
    on_press:
          state: off
    on_release:
          state: on
    on_press:
      - climate.control:
          mode: 'cool'
    on_release:
      - climate.control:
          mode: 'off'
# Studio Air Conditioner Status from HA
    name: "Studio AC Status from HA"
    entity_id: binary_sensor.studio_ac_climate
dallas:
  - pin: D1
#Relay switches
switch:
  - platform: gpio
    pin:
      number: D6
      inverted: True
  - platform: gpio
    pin:
      number: D5
      inverted: True
  - platform: gpio
    pin:
      number: D7
      inverted: True
# Restart
  - platform: restart
    name: "esp1 Studio Restart"
# Studio Outside DHT11 Sensor
  - platform: dht
    model: DHT11
    pin: D2
    temperature:
      name: "Studio DHT Out Temp"
    humidity:
      name: "Studio DHT Humidity"
  - platform: dht
    model: DHT11
    pin: D3
    temperature:
      name: "Studio DHT In Temp"
    humidity:
      name: "Studio DHT In Humidity"
  - platform: dallas
    resolution: 12
    address: <redacted>
#  - platform: dallas
#    id: out_dallas_id
#    resolution: 12
#    address: <redacted>
#    name: studio_out_temp
    on_value:
      then:
      - if:
          condition:
            and:
              # Is the outside temp below 19 and the AC off
              - binary_sensor.is_off: studio_ac_climate
              - lambda: 'return id(studio_dht_out_temp).state < 19;'
          then:
              # Open the damper
                  state: on
              - mqtt.publish:
                  payload: "1"
      - if:
          condition:
            or:
              # Is the outside temp above 19 or the AC on
              - binary_sensor.is_on: ac_status
              - lambda: 'return id(studio_dht_out_temp).state > 19;'
          then:
                  state: off
              - mqtt.publish:
                  payload: "0"
climate:
    min_idle_time: 30s
    min_cooling_off_time: 120s
    min_cooling_run_time: 120s
    name: "Studio Climate Controller"
    cool_action:
      - mqtt.publish:
          payload: "1"
    idle_action:
      - mqtt.publish:
          payload: "0"
And here is the code I am using to run my air conditioner…
esphome:
  platform: ESP32
  on_boot:
  - wait_until:
      condition: api.connected
  - delay: 2s
  - climate.control:
      mode: 'off'
  - mqtt.publish:
      payload: "OFF"
# Enable logging
logger:
#  level: VERBOSE
api:
  reboot_timeout: 0s
ota:
wifi:
  ap:
captive_portal:
status_led:
  pin: GPIO2
dallas:
  - pin: GPIO15
mqtt:
  port: 1883
  reboot_timeout: 0s
  keepalive: 60s
  discovery: false
remote_transmitter:
  pin: GPIO4
climate:
  - platform: daikin
script:
  - id: ac_timer
    then:
          state: ON
      - logger.log: "AC Timer is ON"
      - delay: 20min
          state: OFF
      - logger.log: "AC Timer is OFF"
binary_sensor:
    name: "Studio AC Climate"
    on_press:
      then:
          - climate.control:
              mode: COOL
              fan_mode: AUTO
          - mqtt.publish:
              payload: "ON"
    on_release:
      then:
          - climate.control:
              mode: 'off'
          - mqtt.publish:
              payload: "OFF"
  - platform: dallas
    resolution: 12
    address: <redacted>
    on_value:
      then:
      - if:
          condition:
              - lambda: 'return id(in_ac_dallas).state > 24;'
          then:
              # Open the damper
                  state: on
              - script.execute: ac_timer
              - logger.log: "Telling Climate to START"
      - if:
          condition:
            and:
              - lambda: 'return id(out_temp_studio).state < 18;'
              # Is the inside temp lower than 22
              - lambda: 'return id(in_ac_dallas).state < 22;'
              - binary_sensor.is_off: timer_status
          then:
                  state: off
              - logger.log: "Telling Climate to STOP"
# Studio Outside Temperature from HA
    entity_id: sensor.studio_dht_out_temp
Enjoy!
I’m not able to offer any help but I just wanted to let you know that I appreciate you posting this stuff in here as I’m about to embark on a similar journey and hopefully your work will be of assistance to me.!
Hi. First of all, i appreciate all the efforts put in by you. I see you were the only one updating your code with improvements.
I had a question on whether this will work with cooling and heating? Basically an HVAC.
Right now i am building a solution that is based off home assistant. But i want the solution to be autonomous, same as what you were trying to do.
Thanks for the code
