Hello, I am new to this magical world of home assistant…
I am trying to get educated/pointed at a solution for this:
I have a working esp32 programed to control 4 relays by sensing temperature on 4 probes, this is not through home assistant or esphome, just an Arduino ide program.
The program analyses temperature differences, and calculates whether to turn on or not relays and the timing of cooling to control beer temperature in fermentation tanks.
This is where i need help… I want to use home assistant to only monitor the temperatures and states of relays, display them in a custom dashboard and maybe have a secondary dashboard for temperature changes over time in a 15-20 day period.
So, Is it possible to read variables in an esp-32 program? or lets say, in my built program can I send my program variables as SENSORS so I can play with them in HA.
It is critical that if i loose internet the standalone esp32 keeps running even if i cant monitor the temperatures.
Is it possible? can you push me in the correct path so I can research more about it.
All this can be done in ESP-Home and HA.
I would suggest you port everything to HA/ESP-Home since it will be much easier and reliable than sending values.
Unless the parts is very expensive, buy a new set and tinker with ESP-Home then make the swap and you can have the other parts as spare.
But it won’t be hard.
Thanks, yes i’m thinking on buying a new system (esp32 + relayboard and probes) to learn with it and change the one working later when its robust enough.
Just a question, if there is no internet, does home assistant keep reading and automating? if so, what its its failure point, when the network is down it wont automate at all, right?
If it fails i can loose up to 1000l of beer, so i need to know the risk.
I suggest you create the automation in the ESP as ben says above.
But yes it will work without internet also if done in HA.
However if your router breaks then it won’t work if done in HA.
And that is why we want it to be in ESP-Home, so that you are not reliant on the router.
Why not both systems? Arduino to program everything and HA for monitor the procces.
For the price of a esp32 and some sensors, you can’t risk to lose 1000L beer
I believe MQTT gives you the option of buffering data until the network connection comes back up again if you lose connection. You should not need the greater internet if all devices are on the same local LAN.
Adding an Arduino MQTT subroutine on the ESP32 to spool out your carefully manipulated and debugged data collection process is probably going to be a smaller learning curve than mastering the nuances of ESPHome. You already have your data, and trust it (probably thousands of litres of beer consumed getting there), so just sending it via MQTT should be easy. ESP32 memory capacity may be your limiting factor, both for code and data buffering. Choose your variable types, precision, and formats wisely.
HomeAssistant will take care of storing the arriving MQTT data packets and all the power to do something with it that it entails, including displaying live and historic data in a custom dashboard you can create.
It opens up the power of remote monitoring on your phone, overrides to control your sensors and relays, and show off your setup to your friends over a beer you brewed and poured for them.
