I am running an ESP8266 device not connected to the Internet ( AP Mode ) by using the following settings
wifi:
ap:
ssid: "Hotspot"
password: "password"
ap_timeout: 1s
ota:
# Enable Web Server (optional)
web_server:
local: true
I can connect to the Wifi Hotspot and the Web Interface is shown in a web browser at 192.168.4.1 perfectly.
I have 8 relays connected to 8 GPIO pins and one of the templates just turns on and off each relay in turn.
name: "16 - Go Nuts Switch all with 1s Delay"
optimistic: yes
turn_on_action:
- while:
condition:
lambda: 'return true;'
then:
- switch.turn_on: east_straight
- delay: 1s
- switch.turn_off: east_straight
- delay: 1s
- switch.turn_on: east_turn
- delay: 1s
- switch.turn_off: east_turn
- delay: 1s
- switch.turn_on: south_straight
- delay: 1s
- switch.turn_off: south_straight
- delay: 1s
- switch.turn_on: south_turn
- delay: 1s
- switch.turn_off: south_turn
- delay: 1s
- switch.turn_on: north_straight
- delay: 1s
- switch.turn_off: north_straight
- delay: 1s
- switch.turn_on: north_turn
- delay: 1s
- switch.turn_off: north_turn
- delay: 1s
- switch.turn_on: west_straight
- delay: 1s
- switch.turn_off: west_straight
- delay: 1s
- switch.turn_on: west_turn
- delay: 1s
- switch.turn_off: west_turn
- delay: 1s
- switch.turn_off: go_nuts
turn_off_action:
When you run this, the relays work perfectly, but the “go_nuts” switch remains slid into the “ON” position.
Yet when you run this connected to the Internet ( wifi setup to local access point and IP address set and internet access ok ) the slider works perfectly.
Is there something I am missing or a bug with the slider js when you use local:true
Thanks if anyone has some insights - Martin
