I have a question: If I want to change something in a standard component I could copy it in config/custom_component and edit how I would like it. Is that correct?
You should be able to do this. May I ask what you want to change? Do you have an issue with an integration?
Ok going to try.
Yes, it now runs every 10 seconds and i wan’t to bring back to once a minute
Which integration are you talking about?
Is that correct?
Yes, that is correct
