Dear developers, I am a novice user with respect to Home Automation and therefore am exploring the system with almost everything configured as default. We have a plugwise system in our house with an Anna thermostat controlling our floor heating in the ground floor and several Tom devices controlling the radiators in the second floor all connected to an Adam device.
I have added all Tom devices and the Anna device to Home assistant and created a Dashboard showing the default card for all these devices in one page.
All devices show a circular temperature slider with two numerical temperature values above each other in the center of the circle. The upper numbers in larger font and the lower numbers in smaller font.
What I find strange is that all Tom devices show the set temperature in large numbers above and the actual temperature in small numbers below, while the Anna device shows the actual temperature in large numbers above and the set temperature in small numbers below.
I know that the intention of the system is to modify everything to your own preference, but I think it would be nice if the default card is the same for all devices. To me it would make most sense to set the Tom devices the same way as the Anna devices with the big numbers presenting the actual temperature and the smaller numbers presenting the set temperature.
