Hello everyone, I switched to the internet via Starlink and purchased a raspberry pi4 to improve performance. I therefore carried out a new installation via the raspberry tool to install home assistant. I can’t connect to the interface either in wifi or in ethernet. I use Google Chrome and I always have a DNS error that I can’t resolve. can you help me ? THANKS
If you are having DNS troubles, have you tried connecting via the IP instead of homeassistant.local? you can also try to ping your home assistant with ping 1.2.3.4
← [your HA ip here] and see if it is even possible to make a connection
Did you use Balena Etcher?
Plug a monitor into your pi. What does it show?
