Heya,
Sorry for digging up this post again but for the life of me I cannot get this to work reliably or now at all.
I use a UDM Pro with Starlink in bridge mode on my WAN1 (eth7) port and have a static route setup. I have several LAN subnets/vlans I use and am able to open the http://192.168.1.100 page from a desktop in one subnet and from my mobile using the app in another subnet. Connectivity to the internet and the route to the Starlink local device seems to be good and working as expected.
As a test I did originally have homeassistant running in a VM and found that it was hit and miss, it would connect to starlink and stats would be coming in nicely, then it would stop working for some reason for a few days and I’d get a connectivity error without changing anything network wise, nothing else would have an issue, just the starlink connectivity.
I have since created a dedicated homeassistant server running on an RPi on the same default subnet and vlan (1) as my UDMPro.
The RPi is connected in the same subnet with the port set to the same native vlan and tagged vlans blocked. All connectivity to HA works from any vlan/subnet/device as allowed by the UDMPro.
No matter what I do I cannot get the integration to connect without an ‘Unknown error occurred’ when trying to add starlink 192.168.1.100:9200 in HA.
I have tried experimenting with the route itself, from a .0/24 to a defined .1/32, metrics 1 and 10.
I do understand subnetting, vlans and routes well I am not a novice in this area but for the life of me everything seems to be correct but HA just will not connect, hence I’m here.
A test-netconnection from my desktop PC in a different vlan even returns a TRUE for access to port 9200 on 192.168.100.1.
Using a SSH on the HA I can ping 192.168.100.1 with curl gives me this though:
➜ ~ curl 192.168.100.1:9200
curl: (1) Received HTTP/0.9 when not allowed
Ping and a curl to port 80 work fine though.
Raw connectivity and routing do not seem to be the issue.
Is there some bug I’m not aware of or anything anyone else can suggest?
Cheers.
