Before I raise an issue on GitHub. The documentation for the Starlink Integration is lacking. I cannot connect to the port to set it up. In fact, I scanned all open ports on the router and none of them connect. I am seeing out there that you need a business/enterprise account in order to access the local API. Is this true? Anyone? Thanks.
Works for me on residential gen 2
Make sure you have latest HA. The integration did stop working before an update
Is your HA instance wired, or wireless? Also, what IP address did you put in? The integration does 192.168.100.1:9200 by default. But the defaults on my gen2, the router is at 192.168.1.1
You might need to set up a static route to access it if you’ve set it in bridge mode
Not in bridge mode. What is your plan? Presidential lite or standard?
