Starscream.WSError on an old iPad Mini
Hi Community – I’m having an issue connecting an old iPad through HomeAssistant app to my Home Assistant Instance. It connects fine through Safari but NOT through the app. It throws the following error:
2-04-21 10:06:13.532 [Info] [main] [Environment.swift:71] init() > WebSocket: connecting using HAConnectionInfo(url: https://hass.xxxxxxxxxxx.xxx, userAgent: Optional("Home Assistant/2022.3 (io.robbie.HomeAssistant; build:2022.358; iOS 12.5.5)"), engine: nil)
2022-04-21 10:06:13.556 [Verbose] [main] [Bonjour.swift:54] netServiceDidResolveAddress(_:) >
2022-04-21 10:06:13.668 [Info] [main] [Environment.swift:71] init() > WebSocket: Viability changed: true
2022-04-21 10:06:13.736 [Info] [main] [Environment.swift:71] init() > WebSocket: connected with headers: ["Strict-Transport-Security": "max-age=63072000; includeSubDomains; preload", "Upgrade": "websocket", "Content-Type": "application/octet-stream", "sec-websocket-extensions": "permessage-deflate", "Connection": "upgrade", "sec-websocket-accept": "7FCvAeovASSX1SQhwvv+e/GHzaM=", "Date": "Thu, 21 Apr 2022 09:06:13 GMT", "Server": "Python/3.9 aiohttp/3.8.1"]
2022-04-21 10:06:13.736 [Info] [main] [Environment.swift:71] init() > WebSocket: phase transition to auth
2022-04-21 10:06:13.748 [Error] [main] [Environment.swift:72] init() > WebSocket: Error: Optional(Starscream.WSError(type: Starscream.ErrorType.protocolError, message: "not valid UTF-8 data", code: 1002))
2022-04-21 10:06:13.749 [Info] [main] [Environment.swift:71] init() > WebSocket: phase transition to disconnected(error: Optional(Starscream.WSError(type: Starscream.ErrorType.protocolError, message: "not valid UTF-8 data", code: 1002)), forReset: false)
2022-04-21 10:06:13.749 [Info] [main] [Environment.swift:71] init() > WebSocket: disconnecting; permanently: false, error: Optional(Starscream.WSError(type: Starscream.ErrorType.protocolError, message: "not valid UTF-8 data", code: 1002))
2022-04-21 10:06:13.750 [Info] [main] [Environment.swift:71] init() > WebSocket: phase transition to disconnected(error: nil, forReset: true)
Any idea how to resolve this?
Same issue here with an original iPad Air on iOS 12.5.5
I’m unfortunately seeing the same issue when trying to get my old iPad Air on 12.4.9 to log in :sweat_smile:
Did anyone work this out?
Same problem on iPad Air on 12.5.7 . Any updates on this ?
Same issue, iPhone 6 Plus on 12.5.7 . Maybe it’s something to do with iOS 12?
