Hello to you all!
Much searching here and other places has improved the situation but my Home Assistant installation is still a right mess.
A bit of history. Raspberry Pi and Hassbian were running happily for about a year - using headless system with Sandisk USB drive instead of the SD card. It is mainly used to monitor ground source heat pump (GSHP) with a proprietary interface card. As I wanted to store a lot of metrics I use MariaDB (MySQL) as database. MQTT is used as a transport between the interface card and HA. Another Rpi also uses it with the BME680 chip for environment monitoring.
A few weeks ago the RPi died a death and I suspect that that USB stick was to blame. I did have a backup taken about a month previously (via Etcher) so It thought I could rebuild from that. However, both the original Etcher and the new Balena Etcher would not kick off from “Starting”. Also, my Samsung laptop was crashing regularly with Windows Explorer. In desparation I contacted Samsung who pointed out that I should not have update the laptop to Win10! I suggested that perhaps the laptop should have realised it was not compatible and therefore not suggest the upgrade!
But I digress.
After much hassle, I recovered the original data from the backup and attempted to update HA. It informed me that it was now dependent on a later version of Python and so I updated that too. (3.7).
Whilst attempting to do the rebuild and boot from USB, I noticed that I cannot get it running “headerless” unless I plug in a keyboard and mouse! (I have found similar issues reported but all those fixes do not work here.)
I cannot get any response from HA unless I kick off Hass manually. In the confusion I seem to have configuration.yaml in three different directories too.
For the life of me I cannot understand why I am getting this when I have installed MySQL:
2019-10-03 16:02:52 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup: No module named '_sqlite3' (retrying in 3 seconds)
When executed automatically I get this (sorry about the format - nearly forty years of OpenVMS support is not much use with Linux’s utilities!):
Oct 3 14:24:03 hassbian systemd[1]: Started Permit User Sessions.
Oct 3 14:24:03 hassbian systemd[1]: Started OpenBSD Secure Shell server.
Oct 3 14:24:05 hassbian mysqld[602]: 2019-10-03 14:24:05 1988481024 [Note] /usr/sbin/mysqld (mysqld 10.1.23-MariaDB-9+deb9u1) starting as process 602 ...
Oct 3 14:24:07 hassbian systemd[1]: Started MariaDB database server.
Oct 3 14:24:09 hassbian hass[503]: 2019-10-03 14:24:09 INFO (SyncWorker_1) [homeassistant.util.package] Attempting install of pyotp==2.2.7
Oct 3 14:24:15 hassbian hass[503]: 2019-10-03 14:24:15 ERROR (SyncWorker_1) [homeassistant.util.package] Unable to install package pyotp==2.2.7: ERROR: Could not install packages due to an EnvironmentError: [Errno 13] Permission denied: 'METADATA'
Oct 3 14:24:15 hassbian hass[503]: Check the permissions.
Much searching has got me nowhere with the above error!
I am reluctant to start from absolute scratch as interfacing the code from the GSHP via MQTT took a considerable amount of time. I suspect I have got confused with installation within a virtual environment but never had any hassle before now with it.
(The new version of Python even broke the GSHP code.)
Some lessons learnt for me:
- Do not depend on the USB sticks as they seem to break when used for frequent I/O;
- Sort out an automated backup system - somehow;
- Document steps which work - and especially useful Linux commands!
I still see confusion regarding the various upgrade methods for Home Assistant too. I think a Noddy Guide is needed for the likes of me!
(Please accept my profound apologise for the size of this post!)
And here is the recorder section:
recorder:
db_url: mysql://hass:Password@localhost/homeassistant?charset=utf8
purge_interval: 1
purge_keep_days: 200
include:
domains:
- sensor
- binary_sensor
exclude:
entities:
- sensor.met_office_weather
- sensor.met_office_temperature
- sensor.met_office_wind_speed
