Hello all. Have a question for the hive mind. I know I’m overthinking this. I have home assistant setup in a converted cargo trailer/ camper. I’ve been able to use esphome for a lot of the connections between this and that. What is left is starting and stopping a generator that has a push button start. Basically I need it to see if the generator is running (easy to do with the inverter monitoring that is already setup) and if it is, close a contact (basically push the button) for a few seconds and wait to see if it detects power coming in. If there is, it’s done, if not, close the contact again and repeat the process. I also need it to close the same contact for 30 (I think) seconds when I want to shut it off or the batteries show a specific state of charge. The connections to the esp32 are what has me stumped. The code should be pretty simple. I have a bunch of Wemos D1Mini’s. This should be easy, right???
Yes, it is very much possible. I have setup something similar for my friend. use GPIO switch with 30s time delay to make it as push button which in turn triggers a right sized relays. I am using 30A relay boards for this purpose since I am starting a 2HP pump. Refer here.
If you don’t want to study the electronics of your generator logic board, just use a small relay module to close the button contacts.
Another option is to measure the voltage of the logic board and verify if button is switching low or high side…
Would you be willing to provide some sample code?
It works! Here is tthe codde I used after all the standard ESPHome stuff. THANK YOU!
output:
- platform: gpio
pin: GPIO22
switch:
- platform: output
output: gpio_d1
name: “Gen Start-Stop”
icon: “mdi:generator-mobile”
on_turn_on:- delay: 3500ms
- switch.turn_off: relay1
Good to hear it has worked for you.
