Start automation based on time in state of sensor
I have setup buienalarm which will give me state that next rain is forecasted at 14:15.
With the following state of the sensor 2022-08-19 14:15:00
How to use that time minus 15 minutes to start an automation?
A template trigger:
{{ states('sensor.buienalarm') | as_datetime - timedelta(minutes=15) == now().timestamp() | timestamp_custom("%Y-%m-%d %H:%M:%S", true) }}
wow, very fast and very helpful. I will see in like 20 minutes if it will work as intended :slight_smile:
Note that I just made an edit. I forgot half of the template
It probably didn’t work?
Try this:
{{ (states('sensor.buienalarm') | as_datetime - timedelta(minutes=15)) | string  == (now() | string)[0:19] }}
Cool, this is it!! It worked like a charm, thanks!
