I’ve got a Zappi wallbox and a Dacia Spring. I would like to use HA to start charging when Battery autonomy is under 100km AND after sunset. So far no problem.
But is there an option which I can add to stop charging when the Battery Autonomy reaches 100km. Or do I have to make another automation to do so?
All you need to do is add a second trigger with a trigger id and then a choose block in your actions.
If you post the YAML for your automation, I (or someone else) can show you how to easily do it.
