Start vacuum when leaving home (tado)
I am absolutely new t Home Assistant and have been messing around the last couple of days trying to integrate my Xiaomi Roborock S6 MaxV. I finally succeeded: the vacuum can be controlled via Home Assistant.
Now I want to go one step further and automate the cleaning process.
Therefore I want the vacuum to start whenever everybods in the household has left the house.
Since tado knows when all people have left the house I figured it would be best to use tado as trigger.
Unfortunately this is where all my attempts fail. The system won’t even let me save my attempts.
This is the best I came up with.
platform: state
entity_id: sensor.arbeitszimmer_tado_mode
to: AWAY
  - service: vacuum.start
    entity_id: vacuum.xiaomi_vacuum_cleaner
Can anyone give me a hint o how to proceed?
Would be very thankful.
Regards
Bacardi Man
Your automation is missing several important things, the values for from and to should be in lowercase, and the indentation isn’t quite correct.
Try this:
alias: Start Vacuum
- platform: state
  to: away
If you ever want to know an entity’s actual state values, inspect the entity in Developer Tools > States.
Thank you very much!
Is there a way to prevent the vacuum from starting twice a day?
Should be a condition, right?
Here’s what I suggest, create a History Stats sensor to record the amount of time your vacuum operates during the day (it automatically resets itself at midnight):
  - platform: history_stats
    name: Vacuuming Time Today
    state: 'on'
    type: time
    start: '{{ now().replace(hour=0).replace(minute=0).replace(second=0) }}'
    end: '{{ now() }}'
Now add a condition to your automation that checks if the History Stats sensor reports zero (in other words, the vacuum has not yet logged any operating time today).
alias: Start Vacuum
- platform: state
  to: away
condition: "{{ states('sensor.vacuuming_time_today') | int == 0 }}"
Wow, lightning fast support, thank you!
I insertet the first code into the configuration.yaml
Then I tried to insert the condition into the existing automation.
Unfortunately I then am presented the following message:
Message malformed: Unexpected value for condition: ‘{{ states(‘sensor.vacuuming_time_today’) | int == 0 }}’. Expected numeric_state, state, sun, template, time, zone, and, or, not, device @ data[‘condition’][0]
By the way: would that also be possible:
condition: "{{ states('sensor.vacuuming_time_today') | int >= 60 }}"
Try this version:
alias: Start Vacuum
- platform: state
  to: away
condition:
- condition: template
  value_template: "{{ states('sensor.vacuuming_time_today') | int == 0 }}"
That condition requires the vacuum to have already operated for a certain amount of time ( > 60) before it will execute the action. You want to execute the action only if the vacuum has not operated yet (i.e. allow it to run only once a day).
Thank you very much again.
Now everything seems to work just fine.
I tried to edit your code to int <= 60.
Therefore the vacuum should only start if it hasn’t been running for one hour or longer, since cleaning the whole appartement takes it around 1,5 hours.
I appreciate your help.
You’re welcome!
Please consider marking either my first or second post with the Solution tag (you can only mark one of them). It will automatically place a check-mark next to the topic’s title which signals to other users that this topic has an accepted solution. Effectively, it indicates your issue is resolved and helps users find answers to similar questions.
Dear Taras,
can you please help me out again?
I had to set up Home Assistant from scratch again an can’t get that condition to work.
My configurations.yaml looks like this
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
  - platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
    entity_id: vacuum.roborock_s6_maxv
    state: 'on'
    type: time
    end: '{{ now() }}'
My automation looks like this
platform: state
to: away
for:
  hours: 0
  minutes: 15
  seconds: 0
condition:
  value_template: "{{ states('sensor.vacuuming_time_today') | int <= 0 }}"
device_id: 5ddc124576c87c575f00f42027a0dd66
domain: vacuum
type: clean
But whenever I try to hit that save button I am presented the following message:
Message malformed: Unexpected value for condition: ‘[{‘condition’: ‘template’, ‘value_template’: “{{ states(‘sensor.vacuuming_time_today’) | int <= 0 }}”}]’. Expected and, device, not, numeric_state, or, state, sun, template, time, trigger, zone @ data[‘condition’][0]
What am I doing wrong?
best regards
Bacardi Man
If it looks like that then it’s completely invalid. It has no alias or action and its indentation is wrong in many places.
If you tried to create the automation manually (with a text editor), I suggest you delete it and use the Automation Editor to create it.
Dear Tas,
this the full code from the automation.yaml.
Ist was created by using the Atuomation Editor.
- id: '1648758836666'
  alias: Starte Saugroboter
  description: ''
  - platform: state
    to: away
    for:
      hours: 0
      minutes: 15
      seconds: 0
  condition: []
  - device_id: 5ddc124576c87c575f00f42027a0dd66
    domain: vacuum
    type: clean
  mode: single
best regards
Bacardi Man
I think editing the code in the automation.yaml instead of trying to input the code in the Automation Editor in yaml-view solved the problem.
Thanks guys for the idea.
My automations does the foillowing:
  • vacuum on wed and sat
  • between 07:00 & 11:00
  • start if nobody is at home
  • if not started until 11:00 start @11:00
  • on wed just vacuum bath & wardrobe
  • on saturday vacuum complete apartment
In other wordes, if you leave home, vacuum starts :slight_smile:
So here is what you need:
  • helper: input_boolean.roborock_sterted_today
  • automation to reset helper @00:00 everyday
alias: Reset roborock started today
description: ""
triggers:
  - trigger: time
    at: "00:00:00"
conditions: []
actions:
  - action: input_boolean.turn_off
    metadata: {}
    data: {}
      entity_id: input_boolean.roborock_sterted_today
mode: single
  • automation which starts roborock when somebody leaves home on wed or sat between 07:05 and 11:00
alias: Start roborock if nobody at home or at schedule
description: ""
triggers:
  - entity_id: binary_sensor.anyone_home
    to: "off"
    for:
      hours: 0
      minutes: 15
      seconds: 0
    trigger: state
  - trigger: time
    at: "11:00:00"
conditions:
  - condition: state
    state: "off"
  - condition: time
    weekday:
      - sat
      - wed
  - condition: time
    after: "07:05:00"
actions:
  - action: input_boolean.turn_on
    metadata: {}
    data: {}
  - choose:
      - conditions:
          - condition: time
            weekday:
              - wed
        sequence:
          - data:
              command: set_water_box_custom_mode
              params: 200
              entity_id: vacuum.roborock_s7_maxv
            alias: Kein Mop
            action: vacuum.send_command
          - data:
              command: set_custom_mode
              params: 102
            alias: Vac Mode Balanced
          - data:
              segments:
                - "16"
                - "19"
            action: roborock.vacuum_clean_segment
      - conditions:
          - condition: time
            weekday:
              - sat
        sequence:
          - action: automation.trigger
            metadata: {}
              skip_condition: true
              entity_id: automation.roborock_clean_apartment
mode: single
Have fun
