Starterkit DIY home
I just bought my daughter (10y) a ‘DIY home kit from Keyestudio’ to keep her occupied during summer holiday. She already had a lot of fun with building it, and thinking what she can do with it. My target was to let her play a bit with HA. But sadly, this was not so straight forward. I guess I maybe wiped somewhere the ESP board with my first HA connectivity. But I learned a lot around ESP32 with this kit, so it was positive at the end.
To be honest, I’m very surpised! For this price, you get a real nice package of different sensors (temperature, moisture, humidity, PIR, NFC, gas, buzzer, fan, servo, led, RGB led, display…).
For those who want my esphome yaml file:
esphome:
  friendly_name: "DIY Huis"
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "*************"
  #Used for buzzer music
  services:
    - service: play_rtttl
      variables:
        song_str: string
      then:
        - rtttl.play:
            rtttl: !lambda 'return song_str;'
ota:
  - platform: esphome
    password: "*************"
wifi:
  ssid: *************
  password: *************
  ap:
    ssid: "Keyestudiosmarthouse"
captive_portal:
i2c:
  - frequency: 800kHz
rc522_i2c:
  #RF-Reader
  address: 0x28
display:
  # LCD Screen
  - platform: lcd_pcf8574
    update_interval: 10s
    dimensions: 16x2
    address: 0x27
    lambda: |-
      it.printf(0, 0, "Temp: %.1f C", id(temperature_dht).state);
      it.printf(0, 1, "Vocht: %.1f %%", id(humidity_dht).state);
binary_sensor:
  # Reports if this device is Connected or not
  - platform: status
  # Left push button
  - platform: gpio
    pin:
      number: 16
      inverted: true
  # Right push button
  - platform: gpio
    pin:
      number: 27
      inverted: true
  # GAS Sensor
  - platform: gpio
    pin:
      number: 23
      inverted: true
    device_class: gas
  # PIR Sensor
  - platform: gpio
    pin: 14
    device_class: motion
  # Blue NFC tag - keyholder
  - platform: rc522
    uid: **-**-**-**
    name: "Blauwe Sleutel Tag"
  # White NFC tag - credit card
  - platform: rc522
    uid: **-**-**-**
light:
  # Status LED
  - platform: status_led
    pin: 12
  # 6812RGB Led
  - platform: neopixelbus
    type: GRB
    variant: SK6812
    pin: 26
    num_leds: 4
    effects:
      - pulse:
      - random:
      - strobe:
      - flicker:
      - addressable_rainbow:
      - addressable_color_wipe:
      - addressable_scan:
      - addressable_twinkle:
      - addressable_random_twinkle:
      - addressable_fireworks:
servo:
  # Servo 90 Motor 1
  - id: servo_01
    output: servo_01_out
  # Servo 90 Motor 2
  - id: servo_02
    output: servo_02_out
output:
  # Roof FAN
  - platform: ledc
    pin: 18
    frequency: 100 Hz
  # Roof FAN
  - platform: ledc
    pin: 19
    frequency: 100 Hz
  # Servo 90 Motor 1
  - platform: ledc
    pin: 5
    frequency: 50 Hz
  # Servo 90 Motor 2
  - platform: ledc
    pin: 13
    frequency: 50 Hz
  # Buzzer config
  - platform: ledc
    pin: 25
# Buzzer config
rtttl:
  output: rtttl_out
  on_finished_playback:
    - logger.log: 'Song ended!'
number:
  # Servo 90 Motor 1
    min_value: 0
    initial_value: 0
    max_value: 100
    step: 1
    optimistic: true
    set_action:
      then:
        - servo.write:
            level: !lambda 'return x / 100.0;'
  # Servo 90 Motor 2
    min_value: 0
    initial_value: 0
    max_value: 100
    step: 1
    optimistic: true
    set_action:
      then:
        - servo.write:
fan:
  # Roof FAN L
  - platform: speed
    output: ventilation_fan_pwm_l
    name: "Dak Ventilator L"
  # Roof FAN R
  - platform: speed
    output: ventilation_fan_pwm_r
    name: "Dak Ventilator R"
  # Reports the WiFi signal strength
  - platform: wifi_signal
    update_interval: 60s
  #Temperature and Humidity
  - platform: dht
    pin: 17
    model: dht11
    temperature:
    humidity:
    update_interval: 30s
  # Reports how long the device has been powered (in minutes)
  - platform: uptime
    filters:
      - lambda: return x / 60.0;
    unit_of_measurement: minutes
  # Steam Sensor
  - platform: adc
    pin: 34
    name: "Stoom Water sensor"
switch:
  # Helps to restart the device at distance
  - platform: restart
text_sensor:
  # Reports the ESPHome Version with compile date
  - platform: version
  # Reports WiFi name
  - platform: wifi_info
    ssid:
  # Reports current IP
    ip_address:
I’m maybe just missing the LCD Display to show values from HA. But I want to keep it as ‘base’ as possible, and I’m 100% sure that a lot of improvements will come.
Data in HA
Next step, a dashboard?
I feel I’m going to compete with my daughter for the nicest home. :blush:
btw Maybe a nice ‘building’ kit for starters with HA? Build the hardware, and start with the software… And beside, it’s fun to have this kind of demo home on your desk to test things quickly.
Awesome for you man! I’ve tried and tried to get my daughter to build projects with me and she has 0 interest but can ramble on for 30min about skin care products… I think this is 1000% better use of time than having them staring at any screens.
Speaking of kids… I stumbled into a Boy Scout group that was starting an electronics/soldering/etc program and they needed help making lessons and sourcing all the boards, sensors, led’s, etc. I was so happy to fill boxes of extra components, Arduino’s, esp boards, etc. I hate getting rid of stuff but I was happy to for this good cause.
My point is that other people in here may have similar groups in their community and need help too. If anyone is like me and builds up a rather large “junk drawer” then maybe giving extras away to inspire a child or keep them off the street is something to keep in the back of our minds.
