I am working on a new light integration that gets push updates via websocket. The way I have implemented this is by starting the websocket connection in async_setup_entry in light.py, creating it as a task on the event loop via the hass.async_create_task. This works well with regards to light functionality. The issue I am facing though is that it makes the HA starting time very long with HA saying “Wrapping up startup, not everything will be available until it is finished.” for 3-5 minutes. I assume it is waiting for this task and eventually gives up. Start up time is fast when I don’t call the websocket. HA doesn’t give any warnings about the integration loading time (i.e. saying it takes more than 10 seconds, etc.).
Is there a better way to start the websocket function without causing such a long starting time?
Post a link to your code to help people help you better.
I suspect async_create_task is awated and therefore blocking async_setup_entry returning until some timeout. It is often better to use call later with a small delay to stop this hapening.
Thank you Mark. I prefer not to share my code currently - I am not a programmer and my code is incredibly messy and goes against all rules and regulations (the shame!) (but it works).
I think you are right and I am happy to call it later but I don’t know how or from where. Any suggestions?
All I have in light.py are async_setup_entry, class MyCoordinator(DataUpdateCoordinator) and the entity class. So I am not sure how I call it once async_setup_entry is finished.
You can add a listener to wait for home assistant to have started and use this to call your routine to start you websocket. The developer docs has a great example of how to do this here.
However, instead use homeassistant_start as the event to listen to.
