I just purchased a Lenovo m93p (2.9GHz i5-4570T, 8GB Ram) + Aeon Gen5 Z-Wave Stick. I have a few RPi3 but figured if I snag a dedicated machine to run as a HA server I should be set for awhile.
I have a few questions. The main question is what would everyone suggest is the best way to deploy HA or HASS.IO.
Should I just installed Ubuntu 16.04 server on it. Then follow the installation up with installing hassio as a docker image?
I am new to Docker yet see it kicked around here quite often.
Maybe it would help if you know my existing setup as well.
I curently run a vera plus (basic stuff lighting and door sensors).
I have an outbuilding on my property which I have extended fiber from my home to outbuilding (over 300’ and using media converters to tie it into my existing home network).
I hope to be able to automate the garage doors and lights in outbuilding as well.
I hope to finally make use of my monoprice 6-zone system in my home. I read that this makes use of a Docker image as well.
I am hoping someone can chime in and let me know what is my best route to go as far as installation goes.
Should I just install ubuntu server and run individual docker images for everything or is there a better route?
Keeping in mind I am new to Docker (litteraly read about it hours ago).
I would love to hear other ideas (as I would rather do it right from the start vs. re-build months down the road).
Thanks,
Neil
